Question Joomla legacy mode and Kunena
15 years 2 months ago #104017 by xillibit
What Kunena version are-you using ? Are-you using some Kunena modules/plugins ? If, yes can-you give the versions ?
The topic has been locked.
15 years 2 months ago #104030 by sozzled
I will bet a case of beer that this has nothing to do with Kunena. Any Google search of "Direct access to this location is not allowed" will tell you that you have a Joomla 1.0 extension that you're trying to run on a J! 1.5 website. There are no Joomla extensions written by the Kunena project that will give this kind of error.
The "trick" therefore, is how to find which extension you have that was written for J! 1.0. Msg #9 in this topic contains a short guide to how to detect which extension(s) you have that are not compatible with J! 1.5. One of these days I will update the Wiki article Legacy mode to include this guide.
When you have found an extension that is not compatible with J! 1.0, you need to update it to J! 1.5 or you need to uninstall it. That's the problem, that's what's causing the "Direct Access to this location is not allowed" message, and update/uninistall is the solution.
15 years 2 months ago #104038 by Zylkin
I resolved a problem, blame the CB Plugin.
15 years 1 month ago #106231 by iLucato
Hi Zylkin, I'm facing the same issue. I mean, when I disable Legacy plugin I'm getting also the "direct access to this location is not allowed" error message and as you, I removed all 1.0 components, modules, plugins and template compatibility now are compatible with joomla 1.5.
You said you solved it, I'm using CB too, it's version 1.7. How did you solve it? Would you mind to share the solution?
15 years 1 month ago #106297 by Matias
You still have something legacy installed into your site. I take a terminal to the server and run "grep VALID_MOS * -r | grep -v _JEXEC" in your Joomla root directory.
If you find lines like this:
defined( '_VALID_MOS' ) or die( 'Restricted access' );
You have found the suspect.. Just note that some components like UddeIM and CB itself may have files that are meant only for J1.0..
15 years 1 month ago #106306 by iLucato
Hi Matias, thanks for your reply.
I don't know what is a terminal server and how to execute it. Will that command replace all the VALID_MOS for JEXEC or just find them?
Well, I found in other way a lot of files with _VALID_MOS. My question is, is that ok to replace all VALID_MOS for _JEXEC or it may be unsafe for security reasons on the site or other problem. By changing it, will be allowed to use J! and K! withouth legacy mode on?
Thanks.
