Question Home page not showing
15 years 9 months ago #71476 by Velisa
Home page not showing was created by Velisa
I had the previous version installed and when I activated the Community Builder (latest version) integration, my home page would be blank after a short while (it would take a while to go blank).
I then decided to install V1.6 and I have the same problem. I am running Joomla! 1.5.20. The difference now is that as soon as I install Kunena, my home page is blank immediately. I tried to diable the kunenamenu module too as well as the Forum Integration plugin CB... still have a blank home page. I can go into my history and select any other page and it will load... its just the homepage that has a problem.
I have now unistalled Kunena so that my site can continue to run.
What would make my home page blank? I really like the component and want to use it... I just need to get over this hurdle.
15 years 9 months ago #71485 by subtone
Replied by subtone on topic Home page not showing
Hi Velisa
I don't have the solution for your problem, but maybe I can give you a hint in the correct direction. If I was in your place, the first thing I would to is to enable Error Reporting in the Joomla Backend (Site -> Configuration -> Server -> Error Reporting: Maximum).
Now have a look at your homepage again, you should see some notices/warnings from PHP. Post them here and somebody might be able to help you further...
HTH
sub
15 years 9 months ago #71494 by Velisa
Replied by Velisa on topic Home page not showing
Thanks subtone but when I mean the home page is blank, I mean totally blank as in white. Even if I try enable error reporting, it won't even show any errors.
15 years 9 months ago #71516 by xillibit
Replied by xillibit on topic Home page not showing
Do you have looked into your php error log or into your apache error log ?
15 years 9 months ago #71520 by Velisa
I have asked my hosting company to turn this on for me. I don't currently have it turned on. I also tried the HotFix ( www.kunena.org/forum/12-community-builde...er-integration#62274 ) but this did not help.
Furthermore, I also updated Joomla! to 1.5.22. This is really frustrating and I really want this system to work as it is exactly what I want. What I really don't get is that it takes a few minutes to come right after uninstalling Kunena. When I had the 1.5 version it would take a few minutes before the trouble started and now with 1.6, as soon as I install it, the homepage bombs out.
15 years 9 months ago #71572 by sozzled
Replied by sozzled on topic Home page not showing
I suspect that the website template in this case is completely incompatible with the Kunena component; alternatively, the website has some old, outdated module or plugin that was designed for a previous version of Kunena.
We're getting nowhere fast. It would speed up the resolution of this problem if we saw the user's K 1.6 configuration report.
Time to create page: 0.247 seconds
