- Thank you received: 566
Kunena 7.0.8 Released
Question Hot fix for Kunena 1.6.0-RC3 Community Builder integration
15 years 11 months ago #62274
by Matias
Hot fix for Kunena 1.6.0-RC3 Community Builder integration was created by Matias
Kunena 1.6.0-RC3: There seems to be minor bug in CommunityBuilder integration.
If you go to Joomla backend and CB User Manager, you will get white page.
I've attached minor update which will fix the issue. Just install it by Joomla installer.
15 years 11 months ago #62287
by Scottux
Replied by Scottux on topic Re: Hot fix for Kunena 1.6.0-RC3 Community Builder integration
Thank you very much Mathias.
It's perfect now.
It's perfect now.
15 years 11 months ago #62288
by drlovecat
Replied by drlovecat on topic Re: Hot fix for Kunena 1.6.0-RC3 Community Builder integration
15 years 11 months ago #62551
by wgdejonge
Replied by wgdejonge on topic Re: Hot fix for Kunena 1.6.0-RC3 Community Builder integration
Fixed! Thanks
- Case-Berlin
- Senior Member
- Thank you received: 3
15 years 11 months ago - 15 years 11 months ago #62876
by Case-Berlin
Replied by Case-Berlin on topic solved: blank userprofile (CB 1.2.3 / Kunena 1.6 RC3)
I have recently started a big problem. If I want to open a user profile on the CB, I get a blank page.
J!: 1.5.20
CB: 1.2.3
Kunena 1.6 RC3
UddeIM: 2.1
Mysql: 5.0.51a-3ubuntu5.7
PHP-version: 5.2.4-2ubuntu5.10
Debugmodus from Joomla:
Fatal error: Interface 'iKunena' not found in /var/www/vhosts/derphoenixorden.de/subdomains/st/httpdocs/administrator/components/com_kunena/libraries/api.php on line 17
J!: 1.5.20
CB: 1.2.3
Kunena 1.6 RC3
UddeIM: 2.1
Last edit: 15 years 11 months ago by Case-Berlin.
15 years 11 months ago #62877
by drlovecat
Replied by drlovecat on topic Re: blank userprofile (CB 1.2.3 / Kunena 1.6 RC3)
The following user(s) said Thank You: Case-Berlin
Time to create page: 0.263 seconds
