Question AUP integration not work
And answer to your second post:
If you need a code edits, they should take place after the kunena.com set the position of a stable version ... before that I do not ship any "hack" of information and also I think I no have to...
I've update to K 1.6 RC 2 and AUP still don't work (I can't give point to user and their points are not updated)..
I also realise that in the "integration tab', there's no more AUP box at the bottom part which in K1.6 RC1 do have 'Enable points in profile' & 'Enable rules for points'. However, in kunena profile, there is point shown.
See atachment from Mortti for reference
I didn't mention that the image provided earlier was screen shot from other thread.
Yes, I have already change user notification to AUP. Other setting are as follow:
A. Integration Options
Avatars: Kunena
Profiles and User List:Kunena
Login and Registration:Joomla
Private Messaging:None
Activity Notifications: AUP
Access Control: Joomla
B. AlphaUserPoints
Minimum characters on reply : 50
alel wrote: Hi,
That picture was in Kunena RC1 and now we are in RC2 where that it changed. I have also couple times asked for K dev team while testing process, that they change the description text for the "Activity Notifications" because that don't tell what that setting really do (example this AUP integration)!!
In Finnish that description tell now little bit more...
You have to also enabled pre-installed Kunena rules from the AUP and assing points there for those two rules!!!and AUP still don't work (I can't give point to user and their points are not updated)..
If you are given bonus or some custom points, this have nothing to do with Kunena.(I can't give point to user and their points are not updated)
I will write some public basic "FAQ" of the AUP + Kunena 1.6 integration (as I did for the K 1.5.xx and AUP) when Kunena 1.6 have Stable status...
