- Thank you received: 1
Question AUP integration not work
i can see "minimum characters on reply" only... (please see attached file)
help really appreciated! :dry:
actual versions: joomla 1.5.22, kunena 1.6.2 & alpha user points 1.5.12
The configuration seem correct. Just type 300 charchaters to add points
try to turn Activity stream limit 0
Also, I do not have any problems...darksoul wrote: I havent any problem.
Nope... reinstall AUP, you will not lost nothing of it process, if that not help you... have to be something which do conflict.You dont see rules in AUP? try to reinstall rule.xml
People, please do not use topic "AUP integration not work" in wrong purposes as there is already done in couple times!
Be sure or start a new topic(best choice anyway).
-) upgrade AUP from 1.5.9 to 1.5.12 (install through joomla installer - no uninstall before)
-) not lucky :dry:
-) uninstall AUP (keeping sql-tables - not deleted)
-) fresh install AUP 1.5.12
-) upgrade kunena from 1.6.1 to 1.6.2
-) not lucky :dry:
what can i try next? where can i uninstall rule.xml (only with ftp)? i wanted to uninstall the kunena rules, but they are not visible!? i tried to search them with ftp, but i´m not sure where it should be...?
Last known time of "running system" was before the upgrade from kunena 1.6.0 to 1.6.1.... At this time I had AUP version 1.5.9 - I know this was not good, but I forgot to upgrade AUP before.... :whistle:
I didn´t start a new thread, because I thought it fits in here...
- solpower20
yaksushi wrote: same question as above, it would seem that you can only have AUP give out points for posts or Jomsocial Activity Stream not both.... Am I wrong?
Can anyone shed light on this? I know a ton of people wanting to integrate both JomSocial and Kunena in AUP for activity updates
Try to overwrite or replace with correct kunena rules.
But i think that the problem come from AUP not from Kunena.
