Question Error 500 after installation
16 years 4 months ago #38421 by roeroelectric
I have this problem in the admin panel, with the integration with jomsocial the admin menu is not accessible and appears the error 500, in front-end kunena works properly.
On the site there is installed Jomsocial and Sh404 latest versions.
16 years 4 months ago #38437 by sozzled
Thank you for your reply. Although I do not have any kind of definite answer, I am still trying to determine what has caused your problems.
I understand that your problems only occur when you attempt to use the Kunena administration panel on your website. What I would like to know is this: when did this problem start? Did the HTTP 500 error (in trying to access the Kunena administration panel) start when you upgraded to JomSocial 1.6, while you had K 1.5.8 already installed? Or did your problem start when you upgraded to K 1.5.8 while you already had JomSocial 1.6 installed?
Thank you for adding that you have installed sh504SEF. No doubt you are already aware that sh504SEF has been, in the past, directly responsible for cause numerous problems in running Kunena ... but this is the first time I have heard that it could also be involved in causing problems at the backend. Even so, if you disable sh504SEF does this eliminate the HTTP 500 errors on your site?
16 years 4 months ago #38573 by dcasmr
Thanks for your taking the time to help. For me, it happened after I upgraded to Jomsocial 1.6. I am currebtly running their latest version1.6 285 and it is same prob.
When you click on kunena in admin panel, the error is produced.
16 years 4 months ago - 16 years 4 months ago #38584 by sozzled
In that case I would say that responsibility for fixing the problem lies with JomSocial and not with Kunena. I am moving this discussion from Kunena Support to Kunena User Contributions and Third-Party Options » Extensions, Modules, and Plugins » JomSocial .
Last edit: 16 years 4 months ago by sozzled.
Time to create page: 0.244 seconds
