Question Error 500 after installation
16 years 3 months ago #38336 by roeroelectric
I have installed the latest release of Kunena, but when I open the extension from the admin panel appears error 500.
What is the problem?
16 years 3 months ago #38337 by roeroelectric
I have discovered that the problem is due to the integration with jomsocial, activating this function kunena does n't work.
I have Jomsocial 1.6, latest and recent version.
16 years 3 months ago #38345 by xillibit
If you using a sef components, do you tried to disable it ?
16 years 3 months ago #38366 by sozzled
This may or may not be helpful to this discussion. HTTP 500 errors are quite hard to diagnose but, in the last two weeks, when people have had HTTP 500 errors after installing Kunena, their problems went away after they did installed it again (the second time, successfully). :unsure:
But, as roeroelectric write, maybe the problem has to do with JomSocial?
16 years 3 months ago #38391 by dcasmr
I am experiencing the same thing. Prior to Jomsocial 1.6, I was not having an issue.
So, I believe that it has to do the integration...
16 years 3 months ago #38393 by sozzled
So, are you saying that JomSocial 1.6 worked with a previous release of Kunena and it was the Kunena upgrade that made a mess of things? Or are you saying that everything was working fine until you upgraded to JomSocial 1.6?
Time to create page: 0.235 seconds
