Question Can't access kunena admin panel in admin panel
16 years 10 months ago #36441 by giro76
I have also problem with admin panel in Kunena. When I make a integration with JomSocial (Avatar, Profile or PM), than admin panel didnt work. I have just blank page and must go in DB and change the config back. I use Kunena 1.5.8-1863, JS 1.6.269 and Joomla 1.5.15. In some older instalation working everything fine, tehere I use it Joomla 1.5.14, JS 1.5.248 and Kunena 1.5.4-1730.
Thanks for your help
Giro
16 years 10 months ago #36443 by xillibit
do you have tried to enable debug mode on joomla! configuration panel to see instead of a blank page an error message ?
16 years 10 months ago #36458 by giro76
I can't start debug mode, because than frontend and backend give me just a blank page :(
16 years 10 months ago - 16 years 10 months ago #36461 by xillibit
You have a blank page on the joomla! home page or just on the kunena page ?
You can enable debug by editing the file joomla/configuration.php and set the following line, like that :
var $debug = '0';
At the end of kunena installation do you seen the message "installation successful" ?
Last edit: 16 years 10 months ago by xillibit.
16 years 10 months ago #36464 by giro76
When I switch the debug to On (1) than I have just a blank page in front and also at backend in whole webpage (Joomla). Than I must go to configuration.php and put the 0 manualy there. Install going normally and finish succesfull. I try also older version of Kunena and same problem.
16 years 10 months ago #36466 by xillibit
Do you have set this in your php.ini file :
error_reporting = E_ALL display_errors = On
