Question Can't access kunena admin panel in admin panel
16 years 10 months ago #36479 by giro76
Sorry, but I can't change php.ini, because this website runnig on hosting, where I can't do that :(
16 years 10 months ago #36599 by drknickel
I have the exact same problem.
What can i do against it?
Kunea works normal in the frontend, but errors in the admin:
Warning: require_once(/administrator/components/com_community/libraries/core.php) [function.require-once]: failed to open stream: No such file or directory in /plugins/community/pjgamercard.php on line 4
Kunea newest and Jomsocial 1.6 newest
Thx :)
16 years 10 months ago #36601 by xillibit
Maybe in the control panel of your host, you can change that.
Thx :)
you enabled the plugin pjgamercard in jomsocial which isn't installed
16 years 10 months ago #36608 by Ganzuelo
Youll have to update all plugins to the newest Jomsocial. Also remember if you are using RCs you need to backup your site as they aren't meant to use on live sites.
16 years 10 months ago #36624 by drknickel
How do i update the plugins?
Simply reinstall them?
THx
16 years 10 months ago #36629 by Ganzuelo
yes. look for the new plugin package and reinstall. you might want to disable the gamercard app and see if you can get in. I was getting this error with the all video plugin
