Question Can't access kunena admin panel in admin panel
16 years 10 months ago #36261 by ph33rgear
Everything was working fine, then I decided to see what it would look like "using" jomsocial template in the kunena settings.
now I get this error from the admin panel:
Warning: require_once(/administrator/components/com_community/libraries/core.php) [function.require-once]: failed to open stream: No such file or directory in /plugins/community/jreviews_myreviews.php on line 13 Fatal error: require_once() [function.require]: Failed opening required '/public_html/pcgia.com/administrator/components/com_community/libraries/core.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in public_html/pcgia.com/plugins/community/jreviews_myreviews.php on line 13
I use, jomsocial & jreviews component, which you see the jreview errors above although before I changed the template setting it was fine. I tested it.
In fact, on the front end you can still see it working fine here : pcgia.com/index.php?option=com_kunena&Itemid=166
but as you see looks horrible... although now since I can't access kunena admin I cannot change it back.
anyone have any solutios? Can I manually edit a config file to tell it to use defualt template settings agian?
Thank you very much in advance, I worked all hour and hours setting things up to do this bonehead move and would be very very grateful!
16 years 10 months ago #36270 by xillibit
Maybe you missed to set the integration with jomsocial into jreviews_myreviews ?
If, you change the kunena template, open phpmyadmin , edit the table jos_fb_config and change the value for template.
16 years 10 months ago #36293 by ph33rgear
Is there such a setting? I read the documentation and checked all settings when setting it up and do not recall such a setting, but I will admit, I was pretty anxious and could have easily missed it.
Thanks, I will try that as soon as I get home. I really hope it works :)
16 years 10 months ago #36323 by ph33rgear
hmm seems to be using the default template?
Host: localhost Database: hidden Generation Time: Jan 04, 2010 at 06:23 PM Generated by: phpMyAdmin 2.11.9.5 / MySQL 5.1.30 SQL query: SELECT COUNT(*) AS `Rows`, `template` FROM `jos_fb_config` GROUP BY `template` ORDER BY `template` LIMIT 0, 30 ; Rows: 1 Rows template 1 default_ex
this is print view from jos_fb_config
16 years 10 months ago #36336 by fxstein
What version of jomsocial are you running?
We had the very same issue with the jomsocial 1.6 beta, as some of the internal have changed and the plugins had to be updated to work again with js 1.6
If you are running js 1.6 you will have to get an updated version of the plugin.
We are kind of on the receiving end of this. When you integrate with jomsocial the API tells you what functions to call. Unfortunately the bak end path of some of the code has changed, hence any component integrating with js will no appear to fail.
Hope this helps!
16 years 10 months ago #36358 by ph33rgear
Hope this helps!
Thanks, I am using 1.6. So I just upgraded to the 1.6 RC version which was one newer then mine.
I then uninstalled jomsocial & all plugins, re-installed jomsocial and all plugins and modules.
I am still getting that error though :blush: :S
Is there anything kunena based that I would need to upgrade as well?
any other ideas for me to try?
What I still dont understand is that it was working fine, then after I tried to change the template setting boom. crapped out..
Anyways some more input from you guys would be greatly appreciated.
Thanks!
Time to create page: 0.150 seconds
