Important Problem With Profiles
17 years 1 month ago - 17 years 1 month ago #30093 by Llewen
Replied by Llewen on topic Re:Problem With Profiles
I've installed CB 1.2.1 together with Kunena 1.0.10, and I've got exactly the same problem that the op described, forum rankings and total posts, and maybe karma, are not showing in the CB profile. The fields are there, but they are empty. The forum integration plugin is active.
edit: And as is often the case, as soon as I finally cave in and ask for help, I find the answer I am looking for. For anyone else looking for an answer to the same question, in the CB plugin management for forum integration, you have to have the "Display forum statistics field" set to "In User Profile Status". Glaringly obvious once you've figured it out...
And now I really think I need to go to bed...
Last edit: 17 years 1 month ago by Llewen.
Time to create page: 0.094 seconds
