Important Problem With Profiles
When I Go To Someones Profile (Anyones & Everyones) The Stats Display The Following Error.
Hits: 4
Online Status: ONLINE
Last Online: 87 minutes ago
Last Updated: 5 days ago
Connections: 0
Forum Ranking: ---
All Are Correct Except
Forum Ranking, Total Posts, And Karma,
As You Can See It Just Displays ---
Does Anyone Know How To Fix This ?
Kunena
Installed version: 1.0.8
Community Builder
Your version is : 1.2
This has been a long-standing problem with Community Builder and has been discussed at great length in this forum. At present there has been no official announcement (nor has there been an unofficial timeframe) about the changes that need to be incorporated into Community Builder 1.2 to make it more Kunena-friendly - all this, despite the fact that Kunena has been available for the past six months or so ... as long as CB 1.2 has been around.
I have written much on this subject, both here and at Joomlapolis . Basically, you have two choices:
- You can work around the problems that you've got - there is an unofficial "fix" for your problem (but it doesn't solve everything); or
- Ignore Community Builder as an integration option for Kunena.
Here is a short selection of discussions that we've had on the subject. You will find the answers you're looking for among them (in particular, the famous Tony Woodhouse kludge for integrating Community Builder with Kunena):
- Signatures and message ordering for Community Builder users
- Kunena with CB Profiles Issue (constrast with /forum?func=view&catid=12&id=5708 )
- Is Community Builder Worth Installing? (yes, it is ... but it is worth integrating with Kunena? :S )
- CB tab for Kunena: Causes 500 Internal server error (good reasons why you should use the Tony Woodhouse method!)
- Help needed for CB 1.2 and Kunena Integration (general discussion on all the problems we've encountered trying to integrate CB with Kunena)
- cb_gender field problems (a few reasons why you should not integrate CB with Kunena)
- Question CB and Forum (other problems that occur when you choose to integrate Community Builder with Kunena.
I will conclude on this point. I like both Kunena and Community Builder and I believe that they both deserve our support and encouragement. I think they're both very good products. However, I don't think it's worth agonising over the problems associated in trying to get them to co-operate with one another. You can solve your problems if you put the effort into it; believe me ... I have!
Good luck
sozz
i have posted these problems in the kunena 1.0 section
There are other site management systems, too, like JomSocial, that may suit your purposes (and if you're prepared to pay for them).
The selection of discussions in my earlier post has information about the alternatives. There will be as many alternatives as there are people who respond to this question. It's not an easy choice but, in the end, it's yours to choose. We can only tell you of our experiences and, for every one of us, there will be a completely different experience.
Good luck
