Important Problem With Profiles
17 years 6 months ago #16604 by KaySee
Problem With Profiles was created by KaySee
I Got A Problem With Kunena And Community Builder, But Im Not Sure What The Problem Is Caused By.
When I Go To Someones Profile (Anyones & Everyones) The Stats Display The Following Error.
Hits: 4
Online Status: ONLINE
Last Online: 87 minutes ago
Last Updated: 5 days ago
Connections: 0
Forum Ranking: ---
All Are Correct Except
Forum Ranking, Total Posts, And Karma,
As You Can See It Just Displays ---
Does Anyone Know How To Fix This ?
Kunena
Installed version: 1.0.8
Community Builder
Your version is : 1.2
17 years 6 months ago - 17 years 6 months ago #16610 by sozzled
Replied by sozzled on topic Re:Problem With Profiles
Welcome to our world, Kay See :laugh:
This has been a long-standing problem with Community Builder and has been discussed at great length in this forum. At present there has been no official announcement (nor has there been an unofficial timeframe) about the changes that need to be incorporated into Community Builder 1.2 to make it more Kunena-friendly - all this, despite the fact that Kunena has been available for the past six months or so ... as long as CB 1.2 has been around.
I have written much on this subject, both here and at Joomlapolis . Basically, you have two choices:
  1. You can work around the problems that you've got - there is an unofficial "fix" for your problem (but it doesn't solve everything); or
  2. Ignore Community Builder as an integration option for Kunena.
I've done both and I'm not sure which is the better option (but I'm more inclined towards the second of the two).
Here is a short selection of discussions that we've had on the subject. You will find the answers you're looking for among them (in particular, the famous Tony Woodhouse kludge for integrating Community Builder with Kunena): These are just a few of the matters that you will have to take on board as a result of the choices you make. There are no easy solutions and there is no specific timeframe if (or when) the developers will have the whole "integration" thing worked out.
I will conclude on this point. I like both Kunena and Community Builder and I believe that they both deserve our support and encouragement. I think they're both very good products. However, I don't think it's worth agonising over the problems associated in trying to get them to co-operate with one another. You can solve your problems if you put the effort into it; believe me ... I have!
Good luck :)
sozz
Last edit: 17 years 6 months ago by sozzled.
17 years 6 months ago #16613 by KaySee
Replied by KaySee on topic Re:Problem With Profiles
Is there any alternative to CB ? all i would really like is to have a profile system for my Kunena Forums that has General Info of the person, Post Count, Karma Like System And A Forum Ranking System Also
17 years 6 months ago #16618 by KaySee
I Have Decided To Not Use CB, But i have encountered some problems,
i have posted these problems in the kunena 1.0 section
17 years 6 months ago - 17 years 6 months ago #16619 by sozzled
Yes, Kay See, there are alternatives to Community Builder for what you have in mind. Community Builder, itself, can accommodate your requirements (with a little bit of coaxing, tweaking and manoeuvring on your part ;) ) Good old, vanilla-flavoured Kunena will do everything you've asked for ... out-of-the-box! It depends on what you want your website to be.
There are other site management systems, too, like JomSocial, that may suit your purposes (and if you're prepared to pay for them).
The selection of discussions in my earlier post has information about the alternatives. There will be as many alternatives as there are people who respond to this question. It's not an easy choice but, in the end, it's yours to choose. We can only tell you of our experiences and, for every one of us, there will be a completely different experience.
Good luck :)
17 years 6 months ago #16647 by Matias
Replied by Matias on topic Re:Problem With Profiles
I recommend you to try CB 1.2.1 together with Kunena 1.0.10. We have just released our part and CB will also have the new version out in few hours if no more bugs are found in the testing.
