Kunena 6.4.13 Released
Question Kunena plugin for sh404SEF
There was NO bug, just a missing task of approving. So dont blur this topic, get out.
AceSEF - Joomla! SEO Suite
After this i think there's nothing else i have to comment because your behaviour is evident.
for all others i just suggest to try their free extension before buying thoose not free.
you will see how do they work.
- Philip Roy
- Senior Member
dulici, I'm not quite sure what is going on. On your site I do indeed have no problems. On my two test sites, one worked, but the other brings up a 404 every time with the new files. These sites are on the same VPS server, using the same database and exceptionally common components etc.
The other thing I note is that I still can't turn off legacy mode on my site or else the plugin fails to load my sites template properly when posting a message.....so (without being a developer) I wonder if it is some sort of conflict with other things?
Because I head to the state in 24 hours, I'm going to send you a super admin login to my test site that is failing. You're welcome to have a try and see if you know what might be causing it??
Thanks in advance.
Phil
Philip Roy : Guys, rather than apportioning blame, I'd quite like to work towards getting the issues fixed...this is still the best sh404SEF plugin for Kunena that I've come across, and at least is being worked on a bit for us....and it's free!
Well said Philip! I do agree with you.
We should focus more on fixing the bugs by reporting these to the developer. Instead of criticizing with plain words.
Dulci has done excellent job by developing this important plugin for kunena and keeping it FREE.
Dulci@ I have one problem- whenever someone post new topic the url created lacks itemid which fails my other published modules to load in the forum. I have to purge SEF URL in the backend of Sh404sef after every new post to generate new URL with itemid.
All this started after upgradation my forum from Kunena 1.10 to 1.5.1 version. It was working fine with 1.10 version.
I am not sure whether I am the only which is affected with this bug/error.
sunnyjey you are talking about fixing bugs but as you can see you are wrong because the developer said there aren't. So as he says there's nothing to fix because everything works good. i think this is a closing door. stop.
dulici wrote:
Hey mister pipino, read carefully what I wrote above. In fact I understand your ignorance, you use Google Translate to understand what we write.......
If you upgraded to Kunena 1.5 then you should upgrade your plugin to Kunena 1.5 compatible too.
