Question
Kunena latest posts module - BACKPORTED FOR JOOMLA 1.0
The avatar (%A) isn't showing on my site.. i get the %A as text thou :S
edit: my mistake, the avatar is showing properly when you choose the table layout, it's not showing when you choose list.
%A can't be used as a tooltip format. But it should work with all layouts in item format. Tested on clean installation Joomla 1.0.15 with Kunena 1.0.8 and Kunena Latest 0.0.34.
That was a fast respons.
My system: MySql 5.0.45
PHP5: 5.1.6
Joomla: 1.0.15
Kunena 1.0.8
I got this errormessage when I try to save/apply/cancel the module
Bad Request
Your browser sent a request that this server could not understand.
Client sent malformed Host header
All thing installed in Joomla have apache as owner....
It doesn't look like it's error of this module. Try to install other module (doesn't matter which), if it's not related to other misconfiguration. My module doesn't use something special on backend. Only standard joomla xml file, so there isn't any my code in the backend running.
