Kunena 7.0.8 Released
Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
16 years 4 months ago #43820 by Ciojka
solved sorry.
I was logged in with special permission and was not checked "show special access"
16 years 4 months ago #43868 by King
Replied by King on topic Re:Recent Discussions Module
Thanks for the answers... I like option 1 but I am running K1.5.9. Suppose I will have to upgrade when it becomes available?
16 years 4 months ago #43875 by xillibit
Yes, when these things will be available you will must upgrade.
16 years 4 months ago #43935 by colinstewart
Hi
I've installed mod_kunenalatest 1.0.47.
It is showing posts from July 2009 and not the latest postings and I can't see why.
I have it set to display the last 5 posts.
Any suggestions?
Colin
16 years 4 months ago #43975 by Gazimaluke
So this is my setup. I have three site, but all are based on the same site using the JMS Joomla Multi Site component. Now I want one of the sites to be the main site for the forum, so when someone is in the forums they are on this site.
Now here comes my problem. I want the other sites to be able to use the Kunena latest posts module. And they can, but the URLs in the module will get the user to the forum but on that site. Now I wonder if it is possible to make the module load the lastest posts but make them link to the posts on the forum site.
Have in mind that the three sites use the same Kunena database but different main site templates.
16 years 4 months ago #43981 by greenarrow
jerry wrote:
I am publishing new latest posts module. Try it and send me any comments. I am open to any suggestions, do not hesitate to ask. Thanks, Jerry
Kunena latest module
Highly inspired by Rowan Seymour JBLatest, modified versions by fuQaHa, JoniJM, MetZ. Supports nearly all functionality of all these versions.
Rewritten nearly at all places; to support more features in new Joomla 1.5 and Kunena 1.0.8.
Requirements: Joomla 1.5, Kunena 1.0.8+ or Kunena 1.5.1a+
Highlights:
* Joomla 1.5 design, templates, language file
* Joomla module class suffix and caching
* Supports 1 or 2 column layout; list or table style, multicolumn table style
* Supports multiple instances on page
* Item, tooltip, date/time format (with avatar, text message, number of replies support, thread hits, online status)
* New post indicator support
* Links to profiles (Kunena, JomSocial, Community Builder, Clexus PM)
* Links to avatars (Kunena, JomSocial, Community Builder, Clexus PM)
* Include forums with specific access levels
* Include posts from specific categories, including the active category
* Show all, only first or only last posts from each thread
* Correct link to posts (changed in Fireboard 1.0.5, so all older modules should be updated)
* SEF urls
* Languages: en, fr (by nktine, lavsteph), tr (by ugur), de (by Lintzy), cz (by Fenris), sr (by kmilos)
* Simple upgrade, just install over, it just works
Link to Kunena latest module on extensions.joomla.org
If you like this module, rate it & write review on extension.joomla.org.
Hi Jerry,
i'm using your module on my site. i got this issue on the module. post replies not showing correctly. post that have reply on the forum on the module it shows zero replies.
how can i fix this.
also except avatar how can i add "topic icon" into the place that have avatar currently.
Time to create page: 0.279 seconds
