Question Posts ordering set in kunena admin panel
Attachment hack_posts_ordering_K1-20090719.zip not found
the translation already exists in the kunena.english.php
line 1331-1532
Manager French translation
I don't know if the native Kunena profile edit allows the user to change this but the CB profile does.
So, different users can have different sorts without the need for the hack.
Hope that helps clarify.
However, I am determined so....
I have downloaded hack_posts_ordering_K1-20090719.zip but I have no idea what to do with it.
Could some kind person please offer an idiot-proof step-by-step instruction on what I need to do. I would be most grateful.
I am using Kunena 1.5.7 (and, for what it's worth, Community Builder and CB SuperActivity)
You don't need hack, the changes are already applied in the files in the archive, just put these files in your FTP and replace the older files.
Don't forget to add this in your administrator/components/com_kunena/language/kunena.yourlanguage.php :
For Kunena 1.5.7, you need to use this :
"Parse error: syntax error, unexpected T_STRING in /home2/onesevsi/public_html/upthewestend/administrator/components/com_kunena/language/kunena.english.php on line 35"
Which is strange because line 35 appears to be "define('_KUNENA_JS_ACTIVITYSTREAM_CREATE_MSG1', 'created a new topic');" which I haven't changed.
Any ideas?
Below is a snippet showing everything from the code I added to the offending line 35. I really appreciate your help.
//Hack to reverse order of posts by default see www.kunena.com/forum/114-hacks/20886-pos...it=10&start=10#34344
DEFINE('_COM_A_POSTORDER', 'Define the posts order');
DEFINE('_COM_A_POSTORDER_DESC', 'Define the posts order in two modes : ascending or descending.')
// 1.5.7
