Kunena 6.4.13 Released
Question Posts ordering set in kunena admin panel
I have made a little hack for change directly the post ordering in the kunena config panel, this works only on Kunena 1.5.3. But this need to be adapted if you use an another template that default_ex.
You need to add this, in your administrator/components/com_kunena/language/kunena.yourlanguage.php :
If you don't use the template default_ex, you need just to change this at line 169 :
by this :
Attachment Hack_posts_ordering.zip not found
Great little hack, but it does not work, at least I do not work, does not change the order of the hearing of the messages.
Just assume that if I choose to view messages in "asc" should see the first message in a message created and if I choose to see the messages in "desc" set up to the last message and that message is not so original.
Please could you tell me if you need something more than play the files: admin.kunena.php, admin.kunena.html.php, kunena.language.php and view.php?
Thanks in advance for your answers!
Greetings.
KS!
NO hacer Spam | NO esbribas todo en mayúsculas | Sigue las reglas
I don't know why but my modifications didn't worked, now I have fixed this.
Ok, The try and tell you that it works my brother!
EDIT: Perfect brother, great job! Thank you very much.
Greetings.
KS!
Attachment hack_posts_ordering_K1.zip not found
my proposed amendment for an integrate in all languages.
In admin.kunena.php
replace
Manager French translation
