Question Posts ordering set in kunena admin panel
16 years 4 months ago #34359 by xillibit
I have forgot a coma, this is correct :
DEFINE('_COM_A_POSTORDER', 'Define the posts order'); DEFINE('_COM_A_POSTORDER_DESC', 'Define the posts order in two modes : ascending or descending.');
16 years 4 months ago - 16 years 4 months ago #34362 by Roo
OK. I figured that out. Missing semi-colon. My fault. Error fixed
Nearly there...
So now in the Kunena configuration I get the "Define the posts order" but there are no options to select.
What have I missed? Thanks.
Last edit: 16 years 4 months ago by Roo.
16 years 4 months ago #34407 by Roo
Any suggestions re: the above post? Sorry to be dense. Am trying my best! Thx.
16 years 4 months ago #34418 by xillibit
I have forgot a bit of code, now it's fixed :
File Attachment:
File Name: hack_post_...1209.zip
File Size:50.47 KB
16 years 4 months ago #34444 by Roo
Brilliant! That seems to all work perfectly. Many, many thanks.
16 years 4 months ago #34450 by julianjordan
Thanks a lot!! I wanted to inverse the order too and just by following this thread I was able to make the adjustments and now it is working
Thanks for your help
Julian
Time to create page: 0.245 seconds
