Question Kunena Login Module 1.6 R2
16 years 1 month ago - 16 years 1 month ago #65533 by miamiman
Thanks just tried it, and yes, it resizes the avatar, but still not playing well with CB avatars.
It distorts the png/jpg resolution.:unsure:
Last edit: 16 years 1 month ago by miamiman.
16 years 1 month ago #65542 by loki34829388
well it does change the css styling from a max-width max-height to a fixed width height. I' not sure what size your current avatar is but i can assume if it is smaller than the dimensions you are specifying in the module that it will stretch it to fill the dimensions and thus pixelate it. If it was larger than the dimensions then it should be fine.
in regards to CB avatars looking at the code I can assume it takes the avatar from kunena only as it is interacting with the Kunena API to grab the avatar string.
Good Luck!
16 years 1 month ago - 16 years 1 month ago #65861 by loki34829388
noticing redirect issues may be related to the post data being sent through the kunena component.
I dont really want to hack the component to make a redirect work so i'm rewriting the original joomla login component to have the extra features of avatar, profile link, custom link, custom css and so forth.
so far the login module kunena released is really clean code but it just doesnt seem to function.
the orginal joomla login module interacts with com_users instead as is called for by joomla. So it should be a little more compliant 'i hope' and since kunena doesnt seem to be having problems with it so far I think it would be a viable solution.
I hope to be done early next week if anyone wants me to post it just let me know! cheers.
BTW - I can't seem to find out why the resize patch doesnt work right all the way yet but hopefully it will turn up in a daze somewhere :) anyone figure it out let me know
EDIT - Little checking in my html output and it apears that kunena is grabbing the thumbnail version of avatars so smaller images are being resized can probably correct with a string replace or core hack. think i'll string replace.
EDIT2 - Here is code fore string replaces for fixed dimensions and remove Thumbnail reference
//Begin mod
$avatarlink = str_replace("max-width", "width", $avatarlink);
$avatarlink = str_replace("max-height", "height", $avatarlink);
$avatarlink = str_replace("/tn", "/", $avatarlink); //replace thumbnail reference hack
//end mod
Edit3 - More research CB ha a setting for making thumbnails a certain size you could change that to be a diff size and let your login module work as it did. Though it still would get the avatarLink fo the Thumbnail so not really the way it should be...
Last edit: 16 years 1 month ago by loki34829388. Reason: updates
16 years 1 month ago #65879 by emanuelr
Please post the complete code when available... I believe this is the simplest approach.
16 years 1 month ago #65908 by miamiman
Yes... please post updated code when you have a chance. Thanks!
16 years 2 weeks ago #69776 by @quila
Hi all,
I've tried to reproduce all issues but without success.
I have CB installed, Resizing of Avatar works well, redirect also.
Can someone post here Configuration Report from site where Module dont works properly.
Thank You
