Question Kunena Login Module 1.6 R2
16 years 1 month ago #64475 by miamiman
THis module still needs work apparently...
1. Where do you control the translation of this module? It's not picking up from the component or Joomla settings?
2. The redirect on Log-in is not working? Is this a cache related issue?
3. The sizing of the avatar isn't working either?
Anyway - let us know! Thanks.
16 years 1 month ago #64503 by jackdani82
Hi miamiman,
1. The module has its own language file (language/en_GB/mod_kunenalogin.ini)
2. The redirect causes problems if you use other login-modules at the same time for example
3. Same problems on my page. I use the Community Builder avatar and not the kunena avatar. Maybe there is still a problem.
Also waitig for answers from Kunena team.
16 years 1 month ago #64528 by miamiman
Thanks jackdani,
1. Will do.
2. Yup - I have CB installed.
3. Ditto.
Hopefully future releases will improve this module.
16 years 1 month ago #65134 by miamiman
I'm finding a few issues:
1. I can't modify avatar size.
2. When used in horizontal setup, other modules from same position superimpose themselves on the K-login module.
Any ideas?
16 years 1 month ago #65195 by loki34829388
i'm not sure if it helps you but to solve it for myself i simply did a string replace on the avatar link
$avatarlink = str_replace("max-width", "width", $avatarlink);
$avatarlink = str_replace("max-height", "height", $avatarlink);
after line 77 in function kunenaAvatar
so the function looks like this now
*** begin code
function kunenaAvatar($userid) {
$kunena_user = KunenaFactory::getUser ( ( int ) $userid );
$username = $kunena_user->getName(); // Takes care of realname vs username setting
$avatarlink = $kunena_user->getAvatarLink ( '', $this->params->get ( 'avatar_w' ), $this->params->get ( 'avatar_h' ) );
return CKunenaLink::GetProfileLink ( $userid, $avatarlink, $username );
*** end code
looks like it was building a link with a max-height max-width style and that didnt work so i replaced it after it was built before it was returned.
enjoy!
16 years 1 month ago #65196 by loki34829388
Also. forgot to note.
it is in class.php
