This category is for the plugin developed, endorsed, maintained and supported by the Kunena project team. The topics in this category only relate to the plugin developed for K 1.6 and later versions.
Question Kunena Discuss: Can not make it work
14 years 9 months ago #118829 by chellofr
Thank you for your answers in the previous topic.
My problem is not solved.
I use Joomla 2.5.1 and Joomla article system (not K2) but I can not run the plugin.
I use the plugin: Kunena 1.7.2 Discuss
I have activated the plugin, and applied in "Relation of categories (in French)" the following parameters: 14.5, 15.6;
14 being the category 5 and category Joomla Kunena.
Should I install a type component jcomments for this to work?
Thank you for your clarifications.
SL
14 years 9 months ago #118837 by Jiminimonka
chellofr wrote: I have activated the plugin, and applied in "Relation of categories (in French)" the following parameters: 14.5, 15.6;
Is that highlighted text what you have in the box as it should be 14,5;15,6.
Please read the FAQ.
Only one question per topic.
14 years 9 months ago - 14 years 9 months ago #118875 by sozzled
La virgule (a comma) vs. le point (full-stop) and le point-virgule (semi-colon).
Language translation issues aside, see Discussbot Instructions
Last edit: 14 years 9 months ago by sozzled.
The following user(s) said Thank You: chellofr
14 years 8 months ago #119635 by sissan38
Hello all,
I have the same issue.
I have the Joomla 2.5 version and try to use Kunena Discuss Plugin.
On the categorie links I have set this value : 9,13;
This don't work. When I had a comment the post is added on the Kunena forum ID 7 ... strange !
To be more precise, the ID 9 is my Joomla Category ID 9, and the 13 is the Kunena Category ID 13 corresponding ...
Can you help me please ??
Thanks in advance,
14 years 8 months ago #119646 by sozzled
G'day, sissan38, and welcome to Kunena.
I don't know if we fixed chellofr's problem - there has been no reply - so can we try to help you with your problem and maybe that will help other people.
Can you please post a screen image of your Kunena Discuss parameter settings - like chellofr did - as well as your configuration report. Then we may be in a better position to know what is happening.
14 years 8 months ago - 14 years 8 months ago #119653 by sissan38
Thanks for you help.
Find attached a screenshot of my Discuss Kunena Plugin, and a txt file with the configuration report generated by Kunena.
I confirm you that in the Discuss Kunena Plugin, in the categorie link number I have put a comma, not a point ;)
htaccess: Missing | PHP environment: Max execution time: 50000 seconds | Max execution memory: 90M | Max file upload: 40M
Joomla default template details : blackwidows03 | author: | version: 1.0 | creationdate: 2012-03-02
Third-party components: CommunityBuilder 1.8 | UddeIm 2.6
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Discuss 1.7.2
Last edit: 14 years 8 months ago by sozzled.
Time to create page: 0.151 seconds
