This category is for the plugin developed, endorsed, maintained and supported by the Kunena project team. The topics in this category only relate to the plugin developed for K 1.6 and later versions.
Question link does not work in plugin...
15 years 1 month ago #108739 by Acapulco Kevin
I think we are seeing a trend here. When I used Kunena forum and discuss plugin with Joomla 1.5 and Jomsocial 2.2.4 they worked perfectly. I thought they would be equally compatible with Joomla 1.7 and the Kunena 1.7 versions, but they are not. The incompatibilities are evidently not with Jomsocial but instead with Joomla 1.7
Reading over the bug reports in the forum here lately I see that many people are reporting issues with Kunena 1.7 applications and Joomla 1.7.1 and not so much with Joomla 1.6
15 years 1 month ago #108756 by xillibit
LarsAgerstrand wrote: I use the latest versions, joomla 1.7.1 and kunena 1.7.0
Can-you put here Kunena report configuration setting ?
Acapulco Kevin wrote: I think we are seeing a trend here. When I used Kunena forum and discuss plugin with Joomla 1.5 and Jomsocial 2.2.4 they worked perfectly. I thought they would be equally compatible with Joomla 1.7 and the Kunena 1.7 versions, but they are not. The incompatibilities are evidently not with Jomsocial but instead with Joomla 1.7
Most of users use Joomla! 1.7, so it explain why there are less bug report with Joomla 1.6.x. If you take Joomla! 1.7.1 there are some minors changes into plateform and from Joomla! 1.6.2/1.6.3 there was changes which prevents to load Mootools in backend; so it's changing often...
15 years 1 month ago #108768 by LarsAgerstrand
htaccess: Missing | PHP environment: Max execution time: 600 seconds | Max execution memory: 256M | Max file upload: 1000M
Joomla default template details : jp_american_motorcycle | author: Joomlaplates.com | version: 1.7.001 | creationdate: August 2011
Kunena default template details : Aphotic | author: snilloconator | version: 1.6.0 | creationdate: 2010-23-09
Third-party components: CommunityBuilder 1.7 | UddeIm 2.5
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Discuss 1.7.0
15 years 1 month ago #108777 by xillibit
Login link is incorrect too in the box in the bottom of the page
15 years 1 month ago - 15 years 1 month ago #108778 by Acapulco Kevin
xillibit - On a very personal note, I love your software. It is the best. I do get frustrated when what should be a few clicks turns into a nightmare. I made a big decision to move to Joomla 1.7.1 and it is not your fault that Joomla! wants to update code as often as they have been lately. However, Jomsocial was prepared for this and all their stuff works.
Last edit: 15 years 1 month ago by Acapulco Kevin.
15 years 1 month ago - 15 years 1 month ago #109479 by LarsAgerstrand
I have now changed my template for the site, but still the same problem, the register link does not work.
www.firegear.co.uk/index.php?option=com_...2&Itemid=819&lang=sv
Registrera dig = broken link = Create account
Du behöver logga in eller registrera dig för att delta i diskussionen.
Du har inte rättigheter att se denna sida.
What should I do?
Last edit: 15 years 1 month ago by LarsAgerstrand.
Time to create page: 0.167 seconds
