Sticky [SOLVED] Another menu item has the same alias in Root
15 years 6 months ago #96546 by stellabella
I'd just like to add how much a appreciated your help and support throughout the installation. I love my kunena forum. :cheer:
15 years 6 months ago #96612 by sozzled
Thank you. I'm pleased we were able to help.
I see that you have still not enabled SEO on your site. If you would like assistance in this area, please give me a call.
15 years 5 months ago #97217 by DLCNormal
I am having a problem installing Kunena on a freash install of Joomla 1.6 (not an upgrade). I get the following message:
FAILED Uncaught Exception: Another menu item has the same alias in Root. Root is the top level parent
I have tried several of the suggestions in forum including reviewing the technical requirements (everything seems fine) and deleting menu items with similar aliases. It still doesn't work.
I was able to install Kunena on same hosting service but using Joomla 1.5 and it worked fine. However it doesn't seem to want to install on 1.6, even with a fresh install.
Any suggestions?
15 years 5 months ago - 15 years 5 months ago #97219 by sozzled
G'day, DLCNormal, and welcome to Kunena.
I fixed a problem like this a little while ago - see [SOLVED] Installation problem (although I did not give the exact details of what the problem was or specifically what we did to fix it because it's "tricky") but, if you're interested I might be able to help you.
Last edit: 15 years 5 months ago by sozzled.
15 years 5 months ago #97220 by DLCNormal
15 years 5 months ago #97221 by DLCNormal
Yes, please. I am interested. I used the URL method to install. I am using Joomla! 1.6.0 Stable [ Onward ]
Thanks.
