Sticky [SOLVED] Another menu item has the same alias in Root
15 years 4 months ago #97432 by jjjvandaalen
My problem is the same actually. So I am interested for your offer here too.
After installing I get this error:
... FAILED Uncaught Exception: Een ander menu-item heeft dezelfde alias in de root. Root is hoofdmap op het hoogste niveau (Another menu-item has the same alias in the root. Root is defaultmap on the highest level.)
What could I do about it?
15 years 4 months ago - 15 years 4 months ago #97433 by sozzled
I would like people to read
  1. the messages posted in this topic;
  2. [SOLVED] Installation problem ; and
  3. Uncaught Exception: Another menu item has the same alias in Root. New J! 1.6 installations .
The problem seems to mainly affect new K 1.6.4 installations on J! 1.6. The problem - more particularly, the error message - does not occur in J! 1.5 and does not occur if you have successfully installed K 1.6 on J! 1.6 and people are now upgrading to K 1.6.4.
Last edit: 15 years 4 months ago by sozzled.
15 years 4 months ago #97442 by jjjvandaalen
I get the following error too:
What could I do about this?
Install Kunena
Installeer Kunena
Installer detected failed or interrupted installation attempt!
An incomplete installation of Kunena 1.6.4 build 4832 was found in your system. This means that the installation either failed or was interrupted.
Install Kunena 1.6.4.
HINT: Use this option to complete your installation. This action will create new forum with sample data in it.
WARNING: If you have already installed Kunena 1.6 and then later decided to downgrade back to , any new messages since the upgrade will not be imported using this option. Please migrate your old version instead.
15 years 4 months ago #97444 by jjjvandaalen
Thank you for this answer. I am getting after doing this the next error:
Installeer Kunena
15 years 4 months ago #97446 by sozzled
Please read what I wrote in msg #20
I also suggest that you we deal first with the issues you raised in Installing language stopped: There is no core packet for this language (EN-GB) . Instead of spreading your questions over several topics, let's try to stay focused on what's important.
15 years 4 months ago #97468 by WCSI
I have this same problem. I've read through everything but I don't see anywhere where it describes how to fix the problem.
I already have a site built which I don't really want to build from the ground up just so I can install Kunena first. Is there anyway to get Kunena working? :whistle:
