Question [solved] where are the languages in kunena 1.6 (joomla 1.5.20)?
xillibit wrote: You need to install Joomla! core language for spanish or others languages that you want use, else the kunena language will be not installed.
He wrote:
I have 3 languages in my website: english (default), Italian and German.
Why he should spanish Joomla! Core language installed ? Okey... I see just read that one other user(jeff_j_dunlap) tried to steal the topic... please do your own topic's....
I have these 3 languages (for front-end, not the back-end) in joomla.
Shell I install the languages in my backend too?
How can I completerly remove kunena in order to make a clan-install?
or
how can I add another language to kunena 1.6?
- jeff_j_dunlap
- Junior Member
- Thank you received: 3
- jeff_j_dunlap
- Junior Member
Thank you for your response. This is what I did but it did not work:
- I installed the Joomla core (front end) language and set it to default from the 'Language Manager'.
- Since Kunena was still in English, I reinstalled Kunena. Kunena still in English.
- I decided to look in the directory below and did not see any directory installed for Spanish:
..\components\com_kunena\template\default\language\en-GB
- I relaxed security to a minimum on the site just to make sure that it was not an access issue.
- I reinstalled Kunena and still no Kunena Spanish files. Kunena still in English.
I wouldn't mind manually extracting the language files from the Kunena installation but I am unsure what steps to take or if anything else needs to be edited.
Best Regards,
Jeff
- jeff_j_dunlap
- Junior Member
I can't say why the following files were not installed even after reinstalling but this is how I manually resolved my issue:
In this directory (choose your own language of course):
..\language\es-ES
add these files (choose your own language of course):
es-ES.com_kunena.ini
es-ES.com_kunena.tpl_default.ini
es-ES.com_kunena.tpl_example.ini
The files can be extracted manually from the Kunena 1.6 compressed files.
Your Kunena front end will be in the language of your choice.
P.S. It may be that I had problems because I upgraded my site from K1.5 to K1.6, just guessing though.
