Question [solved] where are the languages in kunena 1.6 (joomla 1.5.20)?
15 years 7 months ago - 15 years 7 months ago #64683
by bredchic
first: thanks for Kunena!
I have joomla 1.5.20 + Joom!Fish Version V2.0.4 + kunena 1.6 (ugraded from 1.5.something yesterday).
I've never used it, but I'm going to soon.
I have 3 languages in my website: english (default), Italian and German.
The question is: even if I switch from a language to another kunena is always in English. Shouldn't it change language? How does it work?
Thanks!
Michele
Thanks!
Michele
Last edit: 15 years 7 months ago by bredchic.
15 years 7 months ago #64784
by xillibit
Replied by xillibit on topic Re: where are the languages in kunena 1.6 (joomla 1.5.20)?
Kunena follow the settings made in language manager, if you set italian you will have italian in kunena too, but i don't know why it's doesn't work in your case.
The following user(s) said Thank You: bredchic
15 years 7 months ago #64796
by bredchic
Replied by bredchic on topic Re: where are the languages in kunena 1.6 (joomla 1.5.20)?
15 years 7 months ago #64805
by bredchic
Replied by bredchic on topic Re: where are the languages in kunena 1.6 (joomla 1.5.20)? here is a bug...
I was also thinking abount this solution (as mine is not a clean install but an upgrade from 1.5.12 and I have nothing to loose):
completely remove kunena and reinstall it. I read that there should be an automatic removing tool but I cannot see it. Can you advice me how to do it?
thanks again
thanks again
- jeff_j_dunlap
- Junior Member
- Thank you received: 3
15 years 7 months ago - 15 years 7 months ago #64861
by jeff_j_dunlap
Replied by jeff_j_dunlap on topic Re: where are the languages in kunena 1.6 (joomla 1.5.20)?
I installed the Spanish (frontend) language and set it as the default language.
Anyway, my Kunena installation is still in English.
I went into the following Kunena directory and no es-ES directory exists, only en-GB as seen here:
..\components\com_kunena\template\default\language\en-GB
Please advise
Please advise
Last edit: 15 years 7 months ago by jeff_j_dunlap. Reason: removed an unecessary comment that may have caused some confusion
15 years 7 months ago #64870
by xillibit
You need to install Joomla! core language for spanish or others languages that you want use, else the kunena language will be not installed.
Time to create page: 0.274 seconds
