Question [solved] where are the languages in kunena 1.6 (joomla 1.5.20)?
16 years 1 day ago - 16 years 1 day ago #64922 by bredchic
Ok, I found this to copmletely remove kunena: www.kunena.com/forum/139-solved-or-prior...how-to-remove-kunena
and I did it.
I reinstalled it (the only one option was: "install kunena 1.6") but nothing, always english only.
I'm going to try with xillibit' solution but I'm not sure it'll work.
The problem is that of I follow the suggestion
The files can be extracted manually from the Kunena 1.6 compressed files
I find only:
it-IT.com_kunena.ini
it-IT.com_kunena.xml
and there's no translation inside.
Last edit: 16 years 1 day ago by bredchic.
16 years 1 day ago - 16 years 1 day ago #64925 by jeff_j_dunlap
bredchic wrote: Ok, I found this to copmletely remove kunena: www.kunena.com/forum/139-solved-or-prior...how-to-remove-kunena
and I did it.
I find only:
I tried Killbits solution about 3 times and it did not work for me unfortunately. That is the reason that I manually copied the files over myself.
I looked at the installation and found the files you mentioned above. Maybe the other two ini files that are included in the Spanish version are not required, just guessing of course. Try it and if it doesn't work, you really have nothing to lose.
Last edit: 16 years 1 day ago by jeff_j_dunlap.
16 years 1 day ago - 16 years 1 day ago #64927 by jeff_j_dunlap
bredchic wrote: and there's no translation inside.
I opened up the file and this is what I saw:
COM_KUNENA_POLL_STATS_NAME="Sondaggio"
COM_KUNENA_ONLINE="Adesso online"
COM_KUNENA_OFFLINE="Offline"
COM_KUNENA_FORUM_INFORMATION="Info Forum"
COM_KUNENA_GO_TO_CATEGORY="Vai alla categoria"
COM_KUNENA_YOU_ARE_HERE="Tu sei quì"
COM_KUNENA_FORUM_HEADER="Header forum"
COM_KUNENA_GLOBAL_SETTINGS="Settaggi globali"
COM_KUNENA_A_GEN_NEWCHAR="NUOVO"
COM_KUNENA_BAN_EDIT="Edita ban"
COM_KUNENA_BAN_NEW="Nuovo ban"
COM_KUNENA_BAN_BANUSER="Ban utente"
...etc
Looks Italian to me :P
16 years 1 day ago - 16 years 1 day ago #64929 by bredchic
yes.Fortunately there's a sort of Italian hero who did it. I'm asking him how to install that staff.
www.operatoresociosanitario.net/forum/20...na-16-italiano#28638
ciao!
Uh, I saw now your answer... maybe you're right. Ok, I try to copy the files in every folder where there is somethins similar. Than I'll let you know.
16 years 1 day ago #64932 by bredchic
GRANDE MAESTROOO!!! UHUUU! :woohoo:
After hours and hours I got it. I must say that Joomla is a good trainer how every time you try to install something, it repeats you: don't give up, in the end it'll work. B)
Thanks.
Anyway, I just copyed the file (the one I found in the Italian hero's post) everywhere I found his en-GB brother. (it-IT.com_kunena.ini - en-GB.com_kunena.ini).
That's it.
Thanks to everybody, please somebody offer a one-way trip to the moon to berlusconi.
Ciao!!
16 years 1 day ago - 16 years 1 day ago #64942 by Mortti
[Little offtopic] I wrote also the new topic for you... hopy it's clear enought for you in the future...
www.kunena.com/forum/107-translations/64...unena-language-files
Last edit: 16 years 1 day ago by Mortti.
The following user(s) said Thank You: jeff_j_dunlap
