Question Upgrade 1.6.0-RC1 to 1.6.0-RC2 Failed!
15 years 8 months ago #59628 by Cerberus
you got the message attachment error because your attachemnt had already been migrated that is an error i got myself and told that its fine and can just be ignored..
15 years 8 months ago - 15 years 8 months ago #59667 by Gamer Templates
OK my forum works fine without errors. But the upgrade function dont work without the site.zip error.
I do this and my forum is up to date:
1) Download RC2
2) Install via Joomla installer
3) Press UPGRADE
4) After Error messages:
Prepare Installation ... OK
Uncompressing admin.zip ... OK
Uncompressing site.zip ... Failed The file '/XXXXXXXXXX/administrator/components/com_kunena/archive/site.zip' could not be uncompressed
you must delete via FTP the 3 .zip files (admin, site & media) in /administrator/components/com_kunena/archive/
5) Then press the RETRY Button and you get this Messages:
Installing System - Kunena plug-in ... OK
Migrate attachments (migrated 0, missing: 2, failed: 0) ... OK
Installation completed successfully. ... OK
7) Now got to your Download Packet and unzip com_kunena_v1.6.0-RC2_b3373_2010-08-31
8) Go to Folder ARCHIVE and unzip the admin, media & site zip in three folders
9) Open your FTP Program and upload:
site.zip -> unzip -> components/com_kunena/
media.zip -> unzip -> media/kunena/
admin.zip -> unzip -> components/com_kunena/
10) Go to Backend -> Components -> Kunena -> and check your Version: You are using the latest version of Kunena 1.6.0-RC2
Have Fun with Kunena!
Last edit: 15 years 8 months ago by Gamer Templates.
The following user(s) said Thank You: Matias
15 years 8 months ago #59774 by Requiem
I have problem to. I uninstall RC1 and try to install RC2. I have error
Duplicate entry '0' for key 1 SQL=INSERT INTO `jos_components` ( `name`,`link`,`menuid`,`parent`,`admin_menu_link`,`admin_menu_alt`,`option`,`ordering`,`admin_menu_img`,`iscore` ) VALUES ( 'Configuration','','0','0','option=com_kunena&task=showconfig','Configuration','com_kunena','0','components/com_kunena/media/icons/config-favicon.png','0' ) SQL = INSERT INTO `jos_components` ( `name`,`link`,`menuid`,`parent`,`admin_menu_link`,`admin_menu_alt`,`option`,`ordering`,`admin_menu_img`,`iscore` ) VALUES ( 'Configuration','','0','0','option=com_kunena&task=showconfig','Configuration','com_kunena','0','components/com_kunena/media/icons/config-favicon.png','0' )
15 years 7 months ago #60256 by Matias
@ templatesROYAL:
Good instructions. But you need to do it in slightly different way to make sure it works.
After getting error message you need to unzip site.zip, media.zip and admin.zip. Then delete those from administrator/components/com_kunena/archive and continue on installation.
@ Requiem:
Did you have Joomla 1.0 earlier? This issue looks like migration issue, where migrator looses all auto increment fields from the database. And the issue is in Joomla -- before any code in Kunena gets run.
15 years 7 months ago - 15 years 7 months ago #60601 by Requiem
No, I`v Joomla 1.5.20. Maybe not correct RC1 uninstall?
[UPDATE]
Problem in Akeeba Backup and auto_increment. Not in Kunena. Problem closed.
Last edit: 15 years 7 months ago by Requiem. Reason: problem closed
Time to create page: 0.220 seconds
