Question Upgrade 1.6.0-RC1 to 1.6.0-RC2 Failed!
15 years 8 months ago - 15 years 8 months ago #59551 by Gamer Templates
Upgrade Kunena from version 1.6.0-RC1 to 1.6.0-RC2
Prepare Installation ... OK
Uncompressing admin.zip ... OK
Uncompressing site.zip ... Failed The file '/XXXXXXXXXX/administrator/components/com_kunena/archive/site.zip' could not be uncompressed
What is wrong?
Info:
Installer detected failed or interrupted installation attempt!
An incomplete installation of Kunena 1.6.0-RC2 build 3373 was found in your system. This means that the installation either failed or was interrupted.
Last edit: 15 years 8 months ago by Gamer Templates.
15 years 8 months ago #59552 by Cerberus
templatesROYAL wrote: Upgrade Kunena from version 1.6.0-RC1 to 1.6.0-RC2
What is wrong?
Info:
permissions error would be my guess check your folder permissions :)
15 years 8 months ago - 15 years 8 months ago #59553 by Gamer Templates
Uncompressing media.zip ... OK
When there is a folder permission i think all zip files have the same problems but only site.zip is the problem and install RC1 works without errors! I dont think that RC1 needs other permission!
ALL FOLDERS HAVE THE SAME PERMISSION! 755!
15 years 8 months ago #59558 by alsvieira
I had the same problem. I connect via FTP and deleted the content of the "/XXXXXXXXXX/administrator/components/com_kunena/archive/" then retry to upgrade and it works. I try to simulate it again but it does not work at first time. Then delete again the content of the ..../archive folder and it works!
Hope this can help,
Take Care;)
The following user(s) said Thank You: John
15 years 8 months ago #59568 by Cerberus
that would make sense alsvieira, thanks for that :) can you try that solution templateroyal and let us know if it works for you too.. :)
15 years 8 months ago - 15 years 8 months ago #59603 by Gamer Templates
MMHH I think that is not the solution!
I have the same failed error when i delete the .zip files in the archive folder. But when i delete the Archive folder and press RETRY the i have this messages:
Installing System - Kunena plug-in ... OK
Migrate attachments (migrated 0, missing: 2, failed: 0) ... OK
Installation completed successfully. ... OK
But i dont think that the site.zip files are unzip. What is the meaning of: Migrate attachments (migrated 0, missing: 2, failed: 0) ... OK
Now i upload all .zip folders via FTP
site.zip -> unzip -> components/com_kunena/
media.zip -> unzip -> media/kunena/
admin.zip -> unzip -> components/com_kunena/
Im testing the forum now!
