Question [Resolved] 1050 an error is occurred .....in the K 1.7 installation
14 years 6 months ago #119676 by marsu95
Hi xillibit,
the issue is that I don't have access to the report.
When I try to move to the configuration panel of Kunena, I receive the following screen : see attached
Let me know how I could give you more relevant information (db unload, some .ini files, ...)
Best regards,
The topic has been locked.
14 years 6 months ago #119700 by sozzled
marsu95 wrote: I reinstall the whole bunch (joomla 2.5.1 full package and KUNENA 1.7.2) in a new environment.
I did not ask you to re-install Joomla and Kunena. I asked you to create a whole new installation, separately from your problem site.
It is my guess that your problem site has a database corruption and, even though it may be possible to fix the problems, we're wasting valuable time. The most important thing we need to test is that you can install Joomla 2.5.1 (and, to make no changes to it, and install nothing else) on a brand new test site with a brand new database. The next most important thing we need to establish is that you can then install Kunena 1.7.2 on that brand new test site. You should follow the installation instructions set out in K 1.6 and K 1.7 Installation Guide
This will take less than one hour to do.
Can you do that and can you tell us if you were able to build a working test site?
14 years 6 months ago #119898 by marsu95
Ho Sozzled,
sorry for late answer, I was off for a couple of days.
I do re install the whole bunch, ..... :S it works !!!!!
I don't understand my previous state but now installation is over.
Thanks a lot for your support.
Regards,
Time to create page: 0.219 seconds
