Question [Resolved] 1050 an error is occurred .....in the K 1.7 installation
14 years 7 months ago - 14 years 7 months ago #119566
by marsu95
Hi guys,
To generate this error while installing the new K 1.7.2. I did the following :
Each time I'm going into the KUNENA component, the following screen is displayed (see KUNENA_installer_screen.doc).
Could you please help me to solve the issue?
Thanks a lot.
- installation of a brand new Joomla 2.5 environment using the Joomla_2.5.1-Stable-Full_Package.zip dowload file. This environment is local (localhost) on a windows XP laptop (see attached the JOOMLA installation screens in file "JOOMLA screens";
- installation of the language extension : fr-FR_joomla_lang_full_2.5.1v2.zip;
- installation of the KUNENA 1.7.2 extension : com_kunena_v1.7.2_b5215_2012-01-31.zip;
- while loaded, activation of the "Install KUNENA 1.7.2." button
Thanks a lot.
Last edit: 14 years 7 months ago by sozzled. Reason: Change topic icon
The topic has been locked.
14 years 7 months ago #119582
by xillibit
Replied by xillibit on topic Re: 1050 an error is occurred .....in the K 1.7 installation
Try by deleting all tables nammed *_kunena_* and redo the installation of Kunena
14 years 7 months ago #119609
by marsu95
Replied by marsu95 on topic Re: 1050 an error is occurred .....in the K 1.7 installation
I did drop all KUNENA tables from the Db then reinstall.
Result is same !
Many thanks for you help.
Result is same !
14 years 6 months ago #119641
Replied by sozzled on topic Re: 1050 an error is occurred .....in the K 1.7 installation
If this is a completely new installation of Joomla with a completely new installation of Kunena, would it be possible to start again?
Perhaps you could try creating a separate new installation of J! 2.5.1 (change nothing) and then try to add K 1.7.2. If this test shows that you can do these two things on your server then it's my conclusion that there's something corrupted in the Joomla database tables in the system you're having problems with.
14 years 6 months ago #119667
by marsu95
Hi sozzled,
I reinstall the whole bunch (joomla 2.5.1 full package and KUNENA 1.7.2) in a new environment.
To secure the installation I reload the JOOMLA and KUNENA packages and clean up the mysql db.
This means that nothing else is installed (Unlike the previous installation, I do not install the FR language package).
Result is same.
Could you reproduce the same in your environment ?
Many thanks for your support.
Best regards.
Result is same.
Best regards.
14 years 6 months ago #119668
by xillibit
Can-you please put here your Kunena report configuration settings ?
Time to create page: 0.226 seconds
