Kunena 7.0.8 Released
Question Upgrade 1.6.2 to 1.6.3 gives white page on the first step
15 years 5 months ago #85293 by xillibit
Baze wrote: Can i download the tables from phpmyadmin, then reinstall kunena and upload them again? Will it work with 1.6.3?
What do you want do exactly ?
Do you tried to install kunena by directory ?
15 years 5 months ago - 15 years 5 months ago #85294 by Baze
I want to get my forum back online :)
currently is stuck on the installation, so i can't do anything :S
I'll try now to install it from directory and i'll let you know, thou i don't have any problem with installation of other components/modules
EDIT: I've tried to install it from directory, i get the same white page :S
Last edit: 15 years 5 months ago by Baze.
15 years 5 months ago #85304 by Baze
Obviously im stuck with this so is there any way i can revert the started update? OR, can i manually update to 1.6.3 just by copying over the files via ftp?
15 years 5 months ago - 15 years 5 months ago #85305 by Baze
I'm terribly sorry for the inconvenience, i have migrated to new server and havent noticed that i have PHP 5.2.17, i'll upgrade now to 5.2.9 and hopefully everything will be fine.
EDIT: Stupid assumption, 5.2.17 is just fine for kunena, it's not the issue... any can anyone PLEASE explain if it's possible to revert the started upgrade process?
15 years 5 months ago #85307 by xillibit
Look the last item in table jos_kunena_version, for the state column make it empty, this will stop upgrade process
The following user(s) said Thank You: Baze
15 years 5 months ago #85309 by Baze
This is the data from the state column:
3 1.0.5RC2 2008-10-27 2009-01-16 817 Redwood
4 1.0.5 2008-12-01 2009-02-18 855 Redwood
5 1.0.6 2009-01-10 2009-02-18 870 Communicate
6 1.0.8 2009-02-17 2009-02-18 1166 Speakup!
7 1.0.10 2009-05-21 2010-06-19 1344 Parier!
8 1.5.11 2010-04-04 2010-06-19 1884 Kirjeldama
9 1.5.12 2010-06-19 2010-07-14 1897 Calificar
10 1.6.0-BETA1 2010-07-19 2010-07-19 3068 Mazungumzo
11 1.6.0-RC1 2010-08-09 2010-08-09 3173 Kujadili
12 1.6.1 2010-11-06 2010-11-17 3858 Timu
13 1.6.2 2010-12-29 2011-01-27 3894 Team
Which row should i delete?
