- Thank you received: 24
To get started please see
K 1.6 & K 1.7 Installation Guide
in our
Documentation Wiki
Question Upgrade 1.6.2 to 1.6.3 gives white page on the first step
15 years 7 months ago #85270
by Baze
Upgrade 1.6.2 to 1.6.3 gives white page on the first step was created by Baze
Hi guys,
i've just tried to updgrade 1.6.2 to 1.6.3, so i got the inital screen ok, and when i've clicked on the upgrade button i got white screen :S no error code, no html, nothing. Now when i click on the components/kunena forum i see the installation screen and only "Prepare Installation ... OK " when i click on the next button i see the white page again
it's a large community so please help me out asap.
The forum runs on J 1.5.22 in native mode with motools 1.2 enabled.
15 years 7 months ago #85272
by xillibit
Replied by xillibit on topic Re: Upgrade 1.6.2 to 1.6.3 gives white page on the first step
Do you have debug mode enabled in Joomla! configuration panel ?
Do you have display error enabled in your php.ini file ?
15 years 7 months ago - 15 years 7 months ago #85273
by Baze
Replied by Baze on topic Re: Upgrade 1.6.2 to 1.6.3 gives white page on the first step
Hi xillibit,
the debugging is disabled, and the error reporting in php.ini is set to "error_reporting = E_ALL & ~E_NOTICE" but the display error was set to off, setting it to on now...
EDIT: Same thing happens after setting the display errors to on, i still see the white page.
Last edit: 15 years 7 months ago by Baze.
15 years 7 months ago #85274
by xillibit
Do you installing Kunena directly from zip or by an another way ?
15 years 7 months ago #85275
by Baze
Directly, dowloaded the zip from here and install it with the joomla installer. Got the firs screen ok, and since then i get the white screen on next. On frontend i see "The Forum is currently offline for maintenance". I can grant you access to my backend if it's any good.
15 years 7 months ago #85282
by Baze
Can i download the tables from phpmyadmin, then reinstall kunena and upload them again? Will it work with 1.6.3?
Time to create page: 0.154 seconds
