Question Fatal error: Cannot redeclare class smile in C:\xampp\htdocs\acupj\components\com_kunena\template\de
Sadly I am not even skilled enough to understand what you mean! Is Kunena 2.0 available and if so should I upgrade to solve the problem?
Thanks again
Please see Support for PC-hosted websites (e.g. WAMP, XAMPP)capdiy wrote: any suggestions on what to do in the meanwhile? Uninstall Kunena and wait?
It's a bad idea to use general class names, which can easily be used by other extensions. We have smile class because of backwards compatibility, so we cannot change that without breaking all external software integrating into Kunena (until 2.0 goes out, that is)..
You can contact the author of the template and ask him to rename class into XTCSmile or something..
Just upgraded to Kunena 1.7 and getting bitten by this issue. The only other component installed is Joomfish and removing doesn't remove the issue. I also try all the J! 1.5.23 templates + JA_Purity which I'm using and problem is still here (I also tried to remove mod_latest). What should I try next?
Thanks.
Fred
