Question Fatal error: Cannot redeclare class smile in C:\xampp\htdocs\acupj\components\com_kunena\template\de
15 years 9 months ago #84203 by capdiy
I have upgraded to the latest version and now get the above error. I am using the JoomlaXTC template "Espresso".
htaccess: Missing | PHP environment: Max execution time: 300 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : jxtc_espresso | author: JoomlaXTC | version: 1.5.1 | creationdate: 2010-11-10
Modules: Kunena Latest: Enabled (Version : 1.0.45) | Kunena Stats: Disabled or not installed | Kunena Login: Disabled or not installed
your help would be appreciated!
15 years 9 months ago #84204 by capdiy
I installed the login plug in and the problem disappeared !
However I now have another problem: I can't register or log in on the front end?
Any suggestions?
15 years 9 months ago - 15 years 9 months ago #84257 by sozzled
Please uninstall the "latest posts" module that was designed for K 1.5. Please read the important information in the K 1.6 release notes about trying to use modules that were designed for K 1.5; these modules will not work.
Please read the very important information about legacy mode . It is very important that users eliminate their dependence on legacy mode. K 1.6 has not been tested under legacy mode conditions. We advise people to not use legacy mode.
I hope this helps. :)
Last edit: 15 years 9 months ago by sozzled.
The following user(s) said Thank You: capdiy
15 years 9 months ago #84272 by capdiy
Thank you!
I disabled "legacy mode", no longer have "latest posts" and have read the 1.6 release notes, but the problem persists! I can log in as admin, but can't create a new user account.
Thanks for any help!
15 years 9 months ago #84273 by capdiy
15 years 9 months ago #84334 by Matias
Unfortunately there's no easy way to make those to work together in Kunena 1.6. This class has been removed from Kunena 2.0, which will work fine.
If you are skilled enough, you can rename one of the classes into something else.
