Important Will not upgrade from 1.61-1.62
15 years 4 months ago #81365 by xillibit
Disable FTP mode into Joomal configuration panel, and re-try installation by directory.
The following user(s) said Thank You: garycpos
15 years 4 months ago #81366 by garycpos
Ok, Thanks that worked ??
So why was that so long winded to achieve, what was causing the problem with ftp on ?
Cheers for your help, it is appreciated :)
Gary
15 years 4 months ago #81368 by xillibit
A permission problem with FTP when creating directory
15 years 4 months ago #81374 by sozzled
garycpos wrote: So why was that so long winded to achieve, what was causing the problem with ftp on?
The answer is that this problem has nothing to do with Kunena. You would have had this problem with other Joomla extensions, too.
Time to create page: 0.228 seconds
