Important Will not upgrade from 1.61-1.62
The Instructions are a joke !! and I have not found one post where it simply states what you must do ?
I have tried from the Extension Manager and it just says "Error uploading File "
I have tried from the install directory and it says "Please enter a package directory"
So !! PLEASE PLEASE ... Has anyone got ANY SIMPLE instructions to follow ....
Seriously Guys, you need to get a simple update procedure in place for your forums, or at least post upgrade instructions that can be followed...
Any Help much appreciated
Gary
It's described right here : docs.joomla.org/Help16:Extensions_Extens...ager_Install#Outline
You can increase the upload_max_filesize into your php.ini if you have access to it
I have emailed justhost.com to set my max_upload to 8mb within php.ini, so it looks like I will wait for that to happen.
Also is there any way for the administrator to edit their own info within the forums ie, add an avatar as I cannot find a way to do this ? or I am blind :S
Cheers
Gary
- snilloconator
- Premium Member
- aka snilly
Also you may want to start another thread for the avatar or use the search function.
* JFTP::store: Bad response
* JInstaller::install: Failed to copy file: /home/cpossys1/public_html/tmp/kunena/kunena.php to /home/cpossys1/public_html/components/com_kunena/kunena.php
Message
* Install Component Error
Also, I have also got the limit raised to 10mb, but when I try to upload it I get a new message now :-
"Unable to find install package"
So both answers have still got me nowhere !!
Any other suggestions ?
Gary
