To get started please see
K 1.6 & K 1.7 Installation Guide
in our
Documentation Wiki
Important Will not upgrade from 1.61-1.62
15 years 4 months ago #81353
by garycpos
Will not upgrade from 1.61-1.62 was created by garycpos
I have never in my life been so frustrated trying to upgrade a package ???
The Instructions are a joke !! and I have not found one post where it simply states what you must do ?
I have tried from the Extension Manager and it just says "Error uploading File "
I have tried from the install directory and it says "Please enter a package directory"
So !! PLEASE PLEASE ... Has anyone got ANY SIMPLE instructions to follow ....
Seriously Guys, you need to get a simple update procedure in place for your forums, or at least post upgrade instructions that can be followed...
Any Help much appreciated
Gary
Gary
15 years 4 months ago #81355
by xillibit
Replied by xillibit on topic Re: Will not upgrade from 1.61-1.62
It's described right here : docs.joomla.org/Help16:Extensions_Extens...ager_Install#Outline
You can increase the upload_max_filesize into your php.ini if you have access to it
15 years 4 months ago #81358
by garycpos
Replied by garycpos on topic Re: Will not upgrade from 1.61-1.62
Thanks for the post but that link does not tell me how to put the kunena upgrade on ?
I have emailed justhost.com to set my max_upload to 8mb within php.ini, so it looks like I will wait for that to happen.
Also is there any way for the administrator to edit their own info within the forums ie, add an avatar as I cannot find a way to do this ? or I am blind :S
Cheers
Gary
Cheers
Gary
- snilloconator
- Premium Member
- aka snilly
15 years 4 months ago #81359
by snilloconator
Replied by snilloconator on topic Re: Will not upgrade from 1.61-1.62
Gary once the package is uploaded their is a step by step process/screen that gives you the option to upgrade to the latest kunena. Very simple actually!
I have installed Kunena on multiple sites flawlessly along with upgrading and or migrating from other boards. I have tried them all (forums for Joomla) and Kunena is the top dawg. Please be patient as the community here is great and will help you with any questions you may have.
Also you may want to start another thread for the avatar or use the search function.
15 years 4 months ago #81360
by xillibit
Unpack kunena into /joomla/tmp/kunena directory and in Joomla! extension manager, choose install by directory and put the path /yourseeverpath/joomla/tmp/kunena
15 years 4 months ago #81364
by garycpos
Hi, Tried that with the directory install and got this :-
* JFTP::store: Bad response
* JInstaller::install: Failed to copy file: /home/cpossys1/public_html/tmp/kunena/kunena.php to /home/cpossys1/public_html/components/com_kunena/kunena.php
Message
* Install Component Error
Also, I have also got the limit raised to 10mb, but when I try to upload it I get a new message now :-
"Unable to find install package"
So both answers have still got me nowhere !!
Any other suggestions ?
Gary
Message
Gary
Time to create page: 0.239 seconds
