Important Help - website is blank after upgrading to Kunena 1.6
15 years 4 months ago #78925 by xillibit
This doc should help you : docs.kunena.org/index.php/How_to_diagnose_blank_page_on_kunena
Do you had read the readme : docs.kunena.org/index.php/Kunena_1.6.1_Read_Me to check the requierements ?
15 years 4 months ago #78938 by Larse
Thanks, but it doesn't help. I'm trying to find a Template that supports Mootool to see if that is the problem. I don't know if my template from JoomlaShack does that.
This is what the debug tells me:
1.SELECT *
FROM jos_session
WHERE session_id = 'nvle1r46v8jsi8ea6oojr631f0'
2.DELETE
FROM jos_session
WHERE ( time < '1293538696' )
3.SELECT *
FROM jos_session
4.UPDATE `jos_session`
SET `time`='1293545896',`userid`='62',`usertype`='Super Administrator',`username`='Larse',`gid`='25',`guest`='0',`client_id`='1',`data`='__default|a:9:{s:15:\"session.counter\";i:29;s:19:\"session.timer.start\";i:1293543641;s:18:\"session.timer.last\";i:1293545785;s:17:\"session.timer.now\";i:1293545858;s:22:\"session.client.browser\";s:127:\"Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)\";s:8:\"registry\";O:9:\"JRegistry\":3:{s:17:\"_defaultNameSpace\";s:7:\"session\";s:9:\"_registry\";a:4:{s:7:\"session\";a:1:{s:4:\"data\";O:8:\"stdClass\":0:{}}s:11:\"application\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:4:\"lang\";s:0:\"\";}}s:11:\"com_plugins\";a:1:{s:4:\"data\";O:8:\"stdClass\":2:{s:4:\"site\";O:8:\"stdClass\":5:{s:12:\"filter_order\";s:8:\"p.folder\";s:16:\"filter_order_Dir\";s:0:\"\";s:12:\"filter_state\";s:0:\"\";s:11:\"filter_type\";s:1:\"1\";s:6:\"search\";s:6:\"kunena\";}s:10:\"limitstart\";i:0;}}s:6:\"global\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:4:\"list\";O:8:\"stdClass\":1:{s:5:\"limit\";i:20;}}}}s:7:\"_errors\";a:0:{}}s:4:\"user\";O:5:\"JUser\":19:{s:2:\"id\";s:2:\"62\";s:4:\"name\";s:15:\"Lars Jørgensen\";s:8:\"username\";s:5:\"Larse\";s:5:\"email\";s:19:\"[email protected]\";s:8:\"password\";s:65:\"e89a42f869b28cc60288a2ee056175a4:Ay2pZh9At3BVV3m0WWjzvKQ9ZbHyuFmE\";s:14:\"password_clear\";s:0:\"\";s:8:\"usertype\";s:19:\"Super Administrator\";s:5:\"block\";s:1:\"0\";s:9:\"sendEmail\";s:1:\"1\";s:3:\"gid\";s:2:\"25\";s:12:\"registerDate\";s:19:\"2010-07-04 10:52:49\";s:13:\"lastvisitDate\";s:19:\"2010-12-28 09:59:15\";s:10:\"activation\";s:0:\"\";s:6:\"params\";s:120:\"admin_language=en-GB\nlanguage=en-GB\neditor=tinymce\nhelpsite=\ntimezone=1\npage_title=Edit Your Details\nshow_page_title=1\n\n\";s:3:\"aid\";i:2;s:5:\"guest\";i:0;s:7:\"_params\";O:10:\"JParameter\":7:{s:4:\"_raw\";s:0:\"\";s:4:\"_xml\";N;s:9:\"_elements\";a:0:{}s:12:\"_elementPath\";a:1:{i:0;s:112:\"/customers/kiteboardingexercises.com/kiteboardingexercises.com/httpd.www/libraries/joomla/html/parameter/element\";}s:17:\"_defaultNameSpace\";s:8:\"_default\";s:9:\"_registry\";a:1:{s:8:\"_default\";a:1:{s:4:\"data\";O:8:\"stdClass\":7:{s:14:\"admin_language\";s:5:\"en-GB\";s:8:\"language\";s:5:\"en-GB\";s:6:\"editor\";s:7:\"tinymce\";s:8:\"helpsite\";s:0:\"\";s:8:\"timezone\";s:1:\"1\";s:10:\"page_title\";s:17:\"Edit Your Details\";s:15:\"show_page_title\";s:1:\"1\";}}}s:7:\"_errors\";a:0:{}}s:9:\"_errorMsg\";N;s:7:\"_errors\";a:0:{}}s:13:\"session.token\";s:32:\"9ba7a9562657b0e012e4d22bd9da95a5\";s:19:\"osolAdminPassPhrase\";s:0:\"\";}'
WHERE session_id='nvle1r46v8jsi8ea6oojr631f0'
15 years 4 months ago #78942 by Larse
I cant find that Log. I've downloaded a log from my webhotel provider, but that's just a huge amount of info, that says nothing to me.
Debug mode in joomla tells me, that something is wrong with "sessions", I think. There is a lot of red writing, but it doesn't say error...
Will it help to uninstall kunena and delete everything relateds to kunena in the database afterwards. If kunena messed up the website, I should be able to undo the chances again. Uninstalling kunena is not enough.
15 years 4 months ago - 15 years 4 months ago #78971 by sozzled
It would help a lot if we could see your K 1.6 configuration report. I'm willing to bet that the "blank page" is probably a HTTP 500 server error, probably generated by some old add-on that was written for an earlier version of Kunena that's still on the website. But that's just a guess, of course. The error log is the key.
Did you get any of these kinds of problems when you tested the upgrade process on your test site?
Last edit: 15 years 4 months ago by sozzled.
15 years 4 months ago #78979 by Larse
I've located the problem to the template. I found a very basic template that works. But my site looks like crap now. It must the Mootools that is not supported correct in my old template. But that's just crap. Looks are important... :(
Time to create page: 3.095 seconds
