To get started please see
K 1.6 & K 1.7 Installation Guide
in our
Documentation Wiki
Important Help - website is blank after upgrading to Kunena 1.6
15 years 4 months ago #78917
by Larse
Help - website is blank after upgrading to Kunena 1.6 was created by Larse
I need some help. After upgrading from Kunena 1.5 to 1.6 my website is totally blank. Check it out here:
www.kiteboardingexercises.com
The backend works fine and I've tried to uninstall it again, but the result is the same. You can't see the website. What can I do?
I've tried to:
Nothing seem to help...
I've tried to:
- uninstall
- deactivate all plugins
- install new plugins
15 years 4 months ago #78918
by Larse
Replied by Larse on topic Re: Help - website is blank after upgrading to Kunena 1.6
If it can help, this is what I did:
- installed 1.6 by migrating from 1.5. Nothing else...
This is other component installed on my site:
- JoomSocial
- hwdVideoshare
- hwdPhotoshare
- JomComment
- MyBlog
- AcyMailing
- Glossery
I've tried to turn off all intergration with Kunena in all components, but nothing helps. The site totally down...
Please help!
- JoomSocial
- hwdVideoshare
- hwdPhotoshare
- JomComment
- MyBlog
- AcyMailing
- Glossery
Please help!
15 years 4 months ago #78919
by fxstein
Replied by fxstein on topic Re: Help - website is blank after upgrading to Kunena 1.6
the webserver error log is your best friend. There must be something installed that is crashing.
Please post the error message form the server log (contact your hosting provider) and the solution should be quick and simple.
Hope this helps!
Hope this helps!
15 years 4 months ago #78921
by Larse
Replied by Larse on topic Serious upgrade problems! My website went blank
I've tried to:
- installed 1.6 by migrating from 1.5. Nothing else... (no, I didn't read the "Before you install Kunena 1.6 - check list"
- JoomSocial (just upgradet to the newest 2.0.3)
- hwdVideoshare
- hwdPhotoshare
- JomComment
- MyBlog
- AcyMailing
- Glossery
I've tried to turn off all integration with Kunena in all components, but nothing helps. The site totally down...
Please help! Nothing seem to work...
I've tried to:
- uninstall
- hwdVideoshare
- hwdPhotoshare
- JomComment
- MyBlog
- AcyMailing
- Glossery
15 years 4 months ago #78922
by Larse
Replied by Larse on topic Re: Serious upgrade problems! My website went blank
Can it be a templete problem? I'm not sure if my templete supports Mootools 1.2. How can I check this?
Can anyone guide me to a templete that does support this, so I can try it out and see if the problem lies there?
15 years 4 months ago #78923
by Larse
I'm running joomla 1.5.22 just so you know...
