Important Help - website is blank after upgrading to Kunena 1.6
15 years 4 months ago #78917 by Larse
I need some help. After upgrading from Kunena 1.5 to 1.6 my website is totally blank. Check it out here: www.kiteboardingexercises.com .
The backend works fine and I've tried to uninstall it again, but the result is the same. You can't see the website. What can I do?
I've tried to:
  • uninstall
  • deactivate all plugins
  • install new plugins
Nothing seem to help...
15 years 4 months ago #78918 by Larse
If it can help, this is what I did:
- installed 1.6 by migrating from 1.5. Nothing else... :(
This is other component installed on my site:
- JoomSocial
- hwdVideoshare
- hwdPhotoshare
- JomComment
- MyBlog
- AcyMailing
- Glossery
I've tried to turn off all intergration with Kunena in all components, but nothing helps. The site totally down... :(
Please help!
15 years 4 months ago #78919 by fxstein
the webserver error log is your best friend. There must be something installed that is crashing.
Please post the error message form the server log (contact your hosting provider) and the solution should be quick and simple.
Hope this helps!
15 years 4 months ago #78921 by Larse
I've tried to:
  • uninstall
- installed 1.6 by migrating from 1.5. Nothing else... (no, I didn't read the "Before you install Kunena 1.6 - check list" :( )
- JoomSocial (just upgradet to the newest 2.0.3)
- hwdVideoshare
- hwdPhotoshare
- JomComment
- MyBlog
- AcyMailing
- Glossery
I've tried to turn off all integration with Kunena in all components, but nothing helps. The site totally down...
Please help! Nothing seem to work...
15 years 4 months ago #78922 by Larse
Can it be a templete problem? I'm not sure if my templete supports Mootools 1.2. How can I check this?
Can anyone guide me to a templete that does support this, so I can try it out and see if the problem lies there?
15 years 4 months ago #78923 by Larse
I'm running joomla 1.5.22 just so you know...
Time to create page: 0.325 seconds
