Question Help whit instalation
15 years 11 months ago - 15 years 11 months ago #73950 by Horus2
Replied by Horus2 on topic Re: Help whit instalation
Hi again sozzled.
I don't know what to do.
Perhaps you didn't read the installation guide properly?
-Maybe, in fact i forgot to dellete instaled lang.
Did you know that you are running a module on your production site that was designed for an old version of Kunena?
- Yes, and i had deleeted it, before the instalation.
Yes, however i desided to leave it like that, so you people, may be able to see something that i can not. :)
Do you want to spend time analysing the cause of a issue that has occurred with your test site or do you want to get your test site running again as soon as possible?
- It is a test site, made for reason to install kunena, i still have my main site, working, so i prefer to try to analyse what whent wrong. Also i have a backup in c-panel, so restoring should be easy.
Last edit: 15 years 11 months ago by Horus2.
15 years 11 months ago #73951 by sozzled
Replied by sozzled on topic Re: Help whit instalation
Horus2 wrote: I decided to leave [my broken test website] like that, so you people, may be able to see something that I can not.
There's a wise saying: "You can't tell which way the train went by looking at the tracks."
There's nothing I can do for you. Perhaps someone else has some ideas. :unsure:
15 years 11 months ago - 15 years 11 months ago #73956 by Horus2
Well, some people can do that actually, i just dont know, i am not a proffecional or programer. How can i explain what my problem is, when i restore the backup? However, i just do not uderstand, whay you asked me all theese questions, when there is nothing you can do? Or maybe all you trying to say is: "There is a wiki, a lot of explanation, do something, what do i care?", if that is the case. You shoud start whit it, like Mortti do.
I will try to restore the backup, uninstall uddleIm, set lang. to english, and will try the installation again. If it is ok or not, i will try not to trouble you people, whith all theese noob stuff.
Cheers!
