Question Help whit instalation
15 years 11 months ago - 15 years 11 months ago #73415 by Horus2
Help whit instalation was created by Horus2
Hi, i have manage to upgrade my Kunena to 1.6, however it seems that i have manage also to broke my test site :) What can i do about it?:)
Adress of my site is:
http://xn--80ak3bk.net/
Adress of the test site for Kunena 1.6 is:
http://xn--80ak3bk.net/testsite/
(it shows currently a blank page)
I can not, also login i backend of my test site. Joomla version for the test site is 1.5.22
Thanks in advance :)
My sql version is 5 and something
I do not know if my template support the reqierd version of moototools.
Last edit: 15 years 11 months ago by Horus2.
15 years 11 months ago #73418 by Mortti
15 years 11 months ago - 15 years 11 months ago #73424 by Horus2
Replied by Horus2 on topic Re: Help whit instalation
Yah, i have read this already, and it was helpfull. However, information there, do not helping me, to slove the situation.
15 years 11 months ago - 15 years 11 months ago #73549 by sozzled
Replied by sozzled on topic Re: Help whit instalation
Your production site (http://xn--80ak3bk.net/) is running K 1.5 so I do not understand how you have managed to upgrade to K 1.6.
I do not understand how Kunena was responsible for breaking your test site (http://xn--80ak3bk.net/testsite/). The way to fix the problem on your test site is to use the backup that you made of your site before you attempted your K 1.6 installation.
Last edit: 15 years 11 months ago by sozzled.
15 years 11 months ago - 15 years 11 months ago #73813 by Horus2
Hi sozzled :) No offence, but what is that you do not understand ?
I have downloaded this: joomlacode.org/gf/download/frsrelease/13...b3858_2010-11-06.zip
Then i upgraded my joomla to 1.5.22
After that i delleted uddleIm
Then i used joomla instaler /from url/, to run the instalation.
The test site, was a mirror to the production one. I have made it, to see if i will be able to install K 1.6
I can made more detailed explanations (all performed to the test site) of my actions if needed.
15 years 11 months ago - 15 years 11 months ago #73924 by sozzled
I understand that your test site is defective. I don't know why it is defective, or how it became defective, but it is defective. Perhaps if you enable Joomla debug mode and look at your webserver error logs you may find out the cause of the defect? We could ask you questions all day and we may (or not) find the cause of the defect.
Perhaps you didn't read the installation guide properly? Perhaps you didn't read the release notes? Did you know that you are running a module on your production site that was designed for an old version of Kunena? You can't use old module with K 1.6 ... it causes the pages where you've used it to break!
On the other hand, if you have a backup, your test site could be restored to normal operation within an hour. The choice is entirely yours. Do you want to spend time analysing the cause of a issue that has occurred with your test site or do you want to get your test site running again as soon as possible?
Let us know your decision and we'll take things from there. :)
The following user(s) said Thank You: Horus2
