Question Installation problems CLOSED
14 years 9 months ago #118012 by Jiminimonka
Delete that information, and then go in your Kunena Configuration and look for the Report Configuration Settings part and paste that information instead of your configuratio.php contents - bad security move there.
Please read the FAQ.
Only one question per topic.
14 years 9 months ago - 14 years 9 months ago #118014 by GoremanX
Replied by GoremanX on topic Re: Installation problems
Never, ever, ever post the contents of your PHP info publicly. That's very bad security practice. I've edited your post so it's not publicly visible anymore, but you may want to consider editing it to remove that info completely. Please read this page to find out how to get your Kunena configuration report .
www.friendlyphotozone.com
Last edit: 14 years 9 months ago by GoremanX.
14 years 9 months ago #118015 by wsidt
Replied by wsidt on topic Re: Installation problems
Thank you. I realised what I had done afterwards. Please can you tell me where the report config file is located?
14 years 9 months ago #118016 by GoremanX
The following user(s) said Thank You: wsidt
14 years 9 months ago #118017 by wsidt
But I cannot even get into the control panel. Every time I try and install I get the message:
Installer detected failed or interrupted installation attempt!
An incomplete installation of Kunena 1.7.1 build 5162 was found in your system. This means that the installation either failed or was interrupted.
the green installer button leads to this message: Table 'easysimplewebsitesc_677372_db2.truejos_truejos_kunena_announcement' doesn't exist SQL=SHOW COLUMNS FROM `Truejos_truejos_kunena_announcement`
Thank you
14 years 9 months ago #118018 by Jiminimonka
Not a SQL expert by any means, but that database name looks wrong it should be truejos_kunena_announcement and even truejos is too big, isn't it 5 letters max including the _ for the Joomla database?
Did you install the Joomla on your website?
