Question Installation problems CLOSED
14 years 9 months ago #118019 by wsidt
Replied by wsidt on topic Re: Installation problems
I went via 123-reg apps
14 years 9 months ago #118023 by GoremanX
Replied by GoremanX on topic Re: Installation problems
it looks like it borked your Joomla installation. The database prefix must be a series of letters 1 to 5 characters long that ends with an underscore (_). I don't know if that service allows you to set your own database prefix or not, but it was done wrong in either case. Time to re-install Joomla.
www.friendlyphotozone.com
14 years 9 months ago #118040 by sozzled
Replied by sozzled on topic Re: Installation problems
wsidt wrote: I definitely have all the up to date technical requirements and I installed it successfully in a localhost site.
If you mean that you created your website on your PC (which is somewhere we cannot see for ourselves), I refer you to Support for PC-hosted websites (e.g. WAMP, XAMPP) .
Is this localhost site the same platform that you will be using when your website will go live?
  • webrus
  • webrus's Avatar
  • New Member
  • New Member
14 years 9 months ago #118182 by webrus
I tried to upgrade to 1.7. The upgrade failed due to not meeting the technical requirements. As a residual problem I cannot administrate Kunena via backend (see attached file).
14 years 9 months ago - 14 years 9 months ago #118186 by xillibit
Like the error message said you need to have at least php 5.2.3 and dom extension in php...
The technicals requirements are given here : docs.kunena.org/index.php/K_1.7/K_1.6_Technical_Requirements
Last edit: 14 years 9 months ago by xillibit.
