Question Installation problems CLOSED
14 years 9 months ago - 14 years 8 months ago #117962 by wsidt
Hi, can anyone help?
I recently installed kunena in a localhost, no problem. Then when I try and install on a different live website I keep getting this error message:
Table 'easysimplewebsitesc_677372_db2.truejos_truejos_kunena_announcement' doesn't exist SQL=SHOW COLUMNS FROM `Truejos_truejos_kunena_announcement`
Nicki
Last edit: 14 years 8 months ago by wsidt. Reason: Solved
14 years 9 months ago #117975 by sozzled
Replied by sozzled on topic Re: Installation problems
I suggest that you read K 1.6 and K 1.7 Installation and Upgrade .
Does your site meet the minimum technical requirements to run Kunena? What kind of database engine are you using?
14 years 9 months ago #118006 by wsidt
Replied by wsidt on topic Re: Installation problems
I definitely have all the up to date technical requirements and I installed it sucessfully in a localhost site.
Really don't know what to do, any help would be appreciated.
14 years 9 months ago #118008 by Jiminimonka
Post your configuration report, un-edited, that may help people find out what the issue is.
Please read the FAQ.
Only one question per topic.
14 years 9 months ago #118009 by wsidt
sorry, where do I find this?
14 years 9 months ago - 14 years 9 months ago #118010 by wsidt
Have found it now:
Last edit: 14 years 9 months ago by GoremanX.
