Question Installation problems CLOSED
Installer detected failed or interrupted installation attempt!
An incomplete installation of Kunena 1.7.1 build 5162 was found in your system. This means that the installation either failed or was interrupted.
the green installer button leads to this message: Table 'easysimplewebsitesc_677372_db2.truejos_truejos_kunena_announcement' doesn't exist SQL=SHOW COLUMNS FROM `Truejos_truejos_kunena_announcement`
Thank you
- Jiminimonka
- Elite Member
- YBAS!
Did you install the Joomla on your website?
www.friendlyphotozone.com
If you mean that you created your website on your PC (which is somewhere we cannot see for ourselves), I refer you to Support for PC-hosted websites (e.g. WAMP, XAMPP) .wsidt wrote: I definitely have all the up to date technical requirements and I installed it successfully in a localhost site.
Is this localhost site the same platform that you will be using when your website will go live?
- webrus
