Question K 1.7 Update or Installation not possible
15 years 2 months ago #106416 by Matias
Don't delete entries in j16_menu, j16_assets and j16_extensions -- or your Joomla installation doesn't work anymore.
JUpgrade had earlier some bugs that break Joomla -- a few of them have been fixed, but the latest version has it's own issues: it doesn't find Kunena 1.7 and has some bugs in plugin/module import at least.
15 years 2 months ago #106453 by Diarmiud
And what can I do now?
15 years 2 months ago #106460 by Matias
If you have just used JUpgrade and that's not your live site, you should start over and do it again.
I would wait for the next version for the component, as current version doesn't work with Kunena 1.7.
15 years 2 months ago #106480 by Diarmiud
Hello Matias,
for you too: Thank you for your help.
But I´m desperated. We had so much work with this test-version (all components are updated, a lot of new contents were integrated, three person work for some weeks on the project in the Joomla 1.7-Version, hundreds of old contents are adjustet) and so we can´t go back to the Joomla 1.6-Version. In two weeks we plan to go live.
And I don´t understand the problem: I have an Joomla 1.7-site and want to integrate Kunena 1.7. I have old datatables from Kunena 1.6.4. Why it is not possible to install the new Kunena-Version? What made JUgrade wrong so that I can´t install? Can I change it?
Or: Is there another way, I could go (maybe intregrate files manual and update the database with a sql-skript)?
Regards
Peter
15 years 2 months ago #106504 by Diarmiud
Maybe it´s easier to install K 1.6.5. - it´s compatible with Joomla 1.7, isn´t it?
15 years 2 months ago #106610 by Diarmiud
Is there a step-by-step-manual available for upgrading K 1.6.4 to K 1.6.5 (by file-transfer)? Perhaps with the necessary SQL-adaptations?
