Question K 1.7 Update or Installation not possible
I solved the problem - here my solution.
I made the normal installation-process with K 1.6.5 on my migrated Joomla 1.7. I got the error message
"class 'kunenafactory' not found" ... com_kunena/class.kunena.php on line 30
Then I took a fresh-install of Joomla 1.7 and installed there K 1.6.5.
Then I took the files from the fresh-install (administrator/components/com_kunena and components/com_kunena) and overwrote with them the other (upgraded- / migrated) version.
And then ... it runs
I had to install a new menu and some other things, but that was no problem.
Now K 1.6.5 runs without problems, but I don´t dare to update further to K 1.7
Regards
Peter
I have a test-installation with the same configuration to play with. Do you want to have a admin-account to test it yourself? (oh, I know thats not your work, but maybe you´re interessted).
Your issue almost looks like directory permission issue: try to uninstall Kunena (together with all its modules and plugins) and install it again, to see what happens.
As you used JUpgrade, I advice you to look into j16_extensions table after uninstalling everything and before installing Kunena again and deleting all Kunena related entries (while it's not installed)... There may be some leftovers and broken stuff also other tables, but please be really, really, really careful if you modify the database as something may break up even if you don't know/see it.
